Need an odd favor.
Old Mar 8, 2008 | 07:08 AM
Verne's Avatar
Verne
Need an odd favor.
I am in the process of swapping form a '98 gauge cluster to an '02 cluster.
Everything is done but the temp sensor. I screwed up and shorted out the sensor and had to order a new one. New one came in and does not work. So I have ordered another and waiting on it. I have double and triple checked everything. I hooked up the original cluster and tried the temp gauge with it and got the same as the '02. Have done all the sensor test in the manual. All points to a bad sensor.
I wanting to double check the out put voltage from the gauge cluster to the sending unit. If some one could pull the lead off the lower sensor on the thermostat housing and let me know the voltage that would be great.
Just want to make sure the gauge cluster doesn't have and issues since it came off my wrecked '02 and has been sitting for a few years.
Thanks,
Verne
Old Mar 8, 2008 | 07:30 AM
drew_c14's Avatar
I'll give it a shot in a few hours. Gotta wait until the kid takes a nap.
Old Mar 10, 2008 | 02:24 PM
Verne's Avatar
Verne
Anybody? I have the new sensor just need to make sure the Cluster isn't frying the sensor.
Thanks,
Verne
Old Mar 10, 2008 | 03:43 PM
drew_c14's Avatar
I knew I forgot something, got caught up in wrapping the headers. Sorry about that. 4.61v on battery.
Old Mar 10, 2008 | 05:05 PM
Verne's Avatar
Verne
Thanks. I'm getting 4.8 to 4.9. Wonder if that is part of my problem or voltmeter just out of speck.
Plugged the new sensor in and grounded it out. Got the same reading from it as the one in it. Guess I better start looking for a new cluster, unless I can figure this out.
Anyone have any ideas?
Thanks,
Verne
Old Mar 10, 2008 | 05:13 PM
drew_c14's Avatar
How is it not working? What is the exact problem?
Old Mar 10, 2008 | 05:32 PM
Verne's Avatar
Verne
As soon as you turn the key on it goes to 250-256 range. Following the test outlined in the manual to unplug the sensor and then ground out the wire to the sensor. When unplugged it goes back to "---" but when grounded out it jumps to 270. That indicates that it is a bad sensor according to the manual. But now wondering if something got messed up in the cluster. If I knew some one close with an '01 or up I would just barrow theirs and try it.
Verne
Old Mar 10, 2008 | 05:42 PM
Thumper's Avatar
Verne, you sure you got a good ground to the cluster itself.
Old Mar 11, 2008 | 01:24 PM
Verne's Avatar
Verne
I checked the other day and it was good. But I am going to do a straight ground to the main frame ground and try that.
Hopefully I can find some one in middle TN with an '01 or up and borrow there cluster to try.
Verne
Old Mar 11, 2008 | 02:19 PM
Verne's Avatar
Verne
Well just got back from a short ride down to fill up the tank to make sure the fuel gauge is working. Worked like a charm. So now I am leaning towards the gauge being bad. Since the whole cluster runs off the same ground and everything else is working as it should.
Verne
Jack Flash
Jun 8, 2015 06:35 PM
Wolverine
Mar 23, 2015 09:36 PM
Hawkrider
May 24, 2012 05:21 AM
inderocker
May 14, 2011 07:01 PM
uchi
Apr 28, 2010 08:09 AM
