3 odd possible Problems
#1 After letting go of the throttle it tends to stay at 3,000 rpm for 1-2 second then drops to normal rpms.
#2 When I sit at a light it knocks then drops rpms and stalls sometimes. #3 I can hear a poof like noise from the front and it decelerates for that poof. |
#1 Is the throttle sticking, or is it after you actually turn the throttle back? I had a my throttle sticking before, it needed cleaning (the actual part that turns on the handle)
#2 Mine did this before I did my CCT's I can't imagine it was related, but after doing the swap it stopped. I think it probably just needed to get more riding time to clean out the jets. #3 No idea, hopefully someone else has something to add here. |
Sounds like you have a vacuum leak. You might have an open vacuum port on one of your carbs, or your intake boots are loose or broken.
What year is your VTR?
(Post 283799)
Originally Posted by NooB
(Post 283796)
I will check them out. |
It may be an intake leak but... I've noticed that 01 and up VTR's do not return to idle as quickly as the previous years. Why? I do not know for sure, but It may have something to do with the updated CDI & ECU for 01 and up VTR's. My VTR does the same thing and the two 2002's, 2003 and 2004 VTR's I've owned did the same thing as well. When I first got my '05 I chased that issue like crazy until I got another late model VTR an found it did the same thing
Originally Posted by lazn
(Post 283792)
#2 Mine did this before I did my CCT's I can't imagine it was related, but after doing the swap it stopped. I think it probably just needed to get more riding time to clean out the jets. #3 No idea, hopefully someone else has something to add here. #2 I think I might have to change the CCT's then. I can hear noise from the chain or the guides or something. Were they easy to change? #3 Pending |
Originally Posted by justinity
(Post 283810)
It is easy, but don't skip any of the steps or you can damage things. |
Lubricate your cables and set your throttle cable freeplay to spec . per service manual (2-6 mm) . Just for starters .
(Post 283808)
Do you mean were the carbs mean the engine or the breather box?
I will check them out. Any luck finding out whats wrong? |
Are #2 and #3 related? Do they happen at the same time sometimes? If so some people call it carb backfiring, or burping. Most guys say a carb sync will fix it, or possible rejetting, and TPS mod.
Any mods done yet? |
