WorkBench.....whats the best height?
Old Nov 28, 2010 | 12:18 AM
j shizzy wizzy's Avatar
mildly retarded
I'm building a workbench and was wondering whats the best height? anyone care to share their workshop building secrets? Any and all comments are appreciated!
thanks all!
Old Nov 28, 2010 | 01:27 AM
PUSHrod's Avatar
Gonna sit or stand?
Some hints:
Install a raised lip on the back and sides to prevent parts search on floor.
Can't have too much light.
Double four gang electrical outlets won't be enough.
Pegboard on the back wall is handy.
Cantilever the supports for underneath storage access.
And at least once a month repair an appliance for the spousal unit in order to maintain territoriality. This will help prevent the horizontal space that you intend to work on from being used for box storage.
Old Nov 28, 2010 | 04:47 AM
uchi's Avatar
good points, as for work height, depends on your height. i like something i dont have to lean over for but at the same time you dont want it too high. for me its right around the belly button, i find its a nice height, i can reach the back, i can see everything, and i dont get back cramps working on things.
Old Nov 28, 2010 | 05:30 AM
NH-Raptor's Avatar
I have two which are of the "purchased" variety and both are 34 inches floor to work surface.
Old Nov 28, 2010 | 05:42 AM
Basic ergonomics say the correct height is where your hands are a couple of inches of the surface with your elbows at 90 degrees... So like uchi said, around your bellybutton for standing work is about right... That position is the most comfortable to work at...
Old Nov 28, 2010 | 08:09 AM
the1bolton's Avatar
the1bolton is on a distinguished road
I have seen some work benches suspended from the ceiling. At first it sounds crazy because it can swing around but if you think about it;
*the space underneath can be used at a later time (say if you want to put your motorcycle there while you work on it).
*When things are half apart, if set up correctly, you can lift it up out of little ones reach (or big ones, depending on the case).
*any height you want; sit stand, upside down...
*if it is sturdy enough you can lower it to the floor to lift something heavier.
*the center of a room's ceiling is often unused. This uses that space effectively.
*and finally... it's fancy.
You could probbaly find a way to attach legs (or just use an existing folding table) to get it to sit on the floor nicely. Anyone doing this might want to consider having the ropes detachable so you can move them out of the way assuming the table has legs in use.
I know, sounds crazy... but I swear it's really convenient for lighter duty projects. For a whole bike engine... I would just skip over to the solid bench.
Old Nov 28, 2010 | 09:01 AM
autoteach's Avatar
All I know is that it depends on the work that I am doing. If it is something that I need to be really steady for and I need to see up close, I love a high top. Almost a chest height. For most other work, I am guessing it is something 36 to 42 inches for me.
Old Nov 28, 2010 | 10:50 AM
Mine's at 38 1/2", and I wouldn't want it any lower, I'm 5'10". It was built into the garage when we bought our house. My 35 year old rollaway fits nicely underneath, along with an old entertainment center after I sawed off the top. That added 3 drawers and 2 cabinets with doors for storage.
I might also add that, with a bar stool, mine's at a good height for sitting and working on the carbs.
And the beer fridge fits on a table right next to it.
Old Nov 28, 2010 | 07:03 PM
mildly retarded
thanks guys, all very useful info.
Old Nov 28, 2010 | 07:45 PM
superbeater's Avatar
42". Craftsman stool if I want to sit. 27" depth. 18" shelf underneath.
Old Nov 29, 2010 | 08:37 AM
I actually like it higher than "proper" since then I am working closer to it and not bending down to see. My arms are easier to bend than my back.
Old Nov 29, 2010 | 09:05 AM
Wicky's Avatar
International Space Station Maintenance Work Area - portable workbench specs - a tabletop that measures 36 inches by 25 inches by 250 miles. When not in use, it is folded and stored inside a drawer.
Pros - just twirl the bike to get access at all areas. Great views.
Cons - fun torquing up nuts & bolts, and cost of tools... $100000!
Old Nov 29, 2010 | 12:41 PM
FL02SupaHawk996's Avatar
Fastest Color
I have 2 of these: http://www.sears.com/shc/s/p_10153_1...u=00914644000P
and 1 of these: http://www.sears.com/shc/s/p_10153_1...9431000P?mv=rr
I like the Craftsman height better...RC
Old Dec 1, 2010 | 04:52 PM
My bench top is @ 36" with a "backstop" but not side stops so long items can be laid out.
These are my shop features:
Bret Cave Features
1. 100 amp electrical service panel and meter
2. 220V sleeve air conditioner
3. Electric heater with separate thermostat
4. Gas heater; pilot-less and sealed heat exchanger (in-progress)
5. Western Mfg. ("HandyLift") motorcycle lift
6. Pit Bull front and rear stands
7. Rubber﷓backed carpeting
8. Window with burglar bars and one-way film
9. Central alarm system
10. Compressed air system (5hp compressor with 60 gallon receiver)
11. Fluorescent and incandescent lighting, including task lighting
12. Electrical outlets every 4 feet plus in the ceiling
13. Hot and cold running water
14. Stereo system
15. Small refrigerator
16. Automatic 6 foot pocket door operated by the same micro﷓remote that opens the 18 foot by 7’﷓6” garage overhead door
17. Insulated gypsum board and/or plywood finished walls and ceiling
18. Electric exhaust system
19. MIG welding machine
20. Work bench with vise
21. Tool cabinet
22. Bead blasting cabinet
23. Shelving & storage cabinets
24. Battery charger with automatic timer
25. Room for two motorcycles
Scoutpilot
Sep 9, 2008 10:00 PM
tremaineiz
Apr 29, 2007 10:15 AM
iamanonymous
Feb 25, 2007 06:33 PM
DDohio
Apr 24, 2006 09:27 AM
NOrrTH
Mar 23, 2006 11:44 AM
