Triumph Speed 4/TT600
Old Nov 24, 2018 | 03:22 PM
ACE VenTRa's Avatar
I'm starting my winter service on my Speed 4, if anyone needs tech tips or photos it is also quite similar to the TT600. Let me know.
Old Dec 9, 2018 | 03:01 AM
ACE VenTRa's Avatar
The service:
Valve adjust
Injectors removed and cleaned
Air filter
Fuel Filter
IAC Clean
IAC Hoses
Oil/Filter
Plugs
Cluck pack clean and inspect
EBC Clutch Springs
The valve adjust on this bike is hoot. Shim under bucket and a not so clear timing arrangement which makes setting TDC a bit of a pain.
If you decide to remove the clutch basket, you most definitely need the clutch holding tool.
Runs awesome now, loves that 34 degree weather.
IAC Hoses are a ridiculous arrangement from the factory, I highly recommend replacing with a high quality silicone line as a matter of course.
EBC Springs are noticeably firmer and grab well without excessive pull required.
That's all for now,
AV
Old Dec 9, 2018 | 07:34 AM
finepooch's Avatar
Shappy1
Apr 14, 2016 07:01 AM
E.Marquez
Jan 9, 2014 11:55 AM
uchi
Apr 9, 2011 03:03 AM
dustinwild
Oct 2, 2007 09:19 AM
superhawk06
Feb 4, 2007 06:48 PM
