Triumph Speed 4/TT600
I'm starting my winter service on my Speed 4, if anyone needs tech tips or photos it is also quite similar to the TT600. Let me know.
The service:
Valve adjust Injectors removed and cleaned Air filter Fuel Filter IAC Clean IAC Hoses Oil/Filter Plugs Cluck pack clean and inspect EBC Clutch Springs The valve adjust on this bike is hoot. Shim under bucket and a not so clear timing arrangement which makes setting TDC a bit of a pain. If you decide to remove the clutch basket, you most definitely need the clutch holding tool. Runs awesome now, loves that 34 degree weather. IAC Hoses are a ridiculous arrangement from the factory, I highly recommend replacing with a high quality silicone line as a matter of course. EBC Springs are noticeably firmer and grab well without excessive pull required. That's all for now, AV |
