WTB: Carb Float
WTB: Carb Float
Hello Again,
It turns out that Honda has carb floats on backorder until Nov 13th at the earliest.
Does anyone out there have a working spare carb float they can sell me?
Help! ;-)
Help! ;-)
Depending on how it is broken, you could try some metal work solder:
http://www.bernzomatic.com/products/...rk-solder.aspx
It is a fairly high heat solder and you'd need a torch to use it.. But it will create a fairly strong bond. Though I'd see this as a "get me through the weekend" fix, and not a permanent one.
Ah I did think it was metal (never had mine apart) You could try plastic welding.. I did that on my seat cowl.. but it isn't as picky about tolerances.
Edit, or try gluing a small piece of tin on there.. but glue and gasoline... hmm
I see you got carbs from IndieRocker, so perhaps that is your best bet.
