WANTED:Carb Float Valve
Old Jan 28, 2012 | 01:10 PM
Squid's Avatar
Bought new from dealer and isnt sealing, Will be available next Monday for pick up but my ride is Saturday. Any help? Name your price!
Old Jan 28, 2012 | 01:52 PM
Have you tried cleaning the valve seat out with a Q tip?
If you have a new valve and can't see a defect, then the problem could be something stuck on the seating area.
Also take a good look at the seat and look for scoring, which would mean you need a new set of carbs.....
Old Jan 28, 2012 | 01:56 PM
If you have any questions on what to do, shoot me a PM with your # and I'll give you a call and walk you through it
Old Jan 28, 2012 | 01:57 PM
Squid's Avatar
I did use a q-tip, looked in seat, no scoring (thank God). Have you ever heard of the floats going out of adjustment? I know that they are not adjustable. I'll go look at the seat again.
Old Jan 28, 2012 | 02:01 PM
The floats are not adjustable, like you said. Your only option with them is to replace them if they are out of spec.
Have you checked your floats for leaks? If not hold them underwater and look for bubbles.....
Old Jan 28, 2012 | 02:10 PM
Squid's Avatar
PM Sent
Old Jan 28, 2012 | 02:27 PM
Partsman's Avatar
Partsman is an unknown quantity at this point
I agree
Originally Posted by Squid
PM Sent
Hawk is correct. No adjustment.... I have a float you can have if you pay shipping. My Zip is 37421
Old Jan 28, 2012 | 02:40 PM
Squid's Avatar
I am going to double-check the height and see if it leak free. If either are out of spec I'll take it. Do you know for a fact that it is in spec? Thanks
Old Jan 28, 2012 | 02:42 PM
Partsman's Avatar
It was working fine when removed....
Old Jan 28, 2012 | 03:03 PM
Squid's Avatar
Alright, Well Thanks for all the help guys. Double checked everything and found a hairline cut in the valve rubber from tip to base. Found it while cleaning the valve with a paper towel. SOL for now. Would like to think that I didnt do that but o-well.
Old Jan 28, 2012 | 03:05 PM
Partsman's Avatar
i can send you a valve as well
Old Jan 28, 2012 | 03:23 PM
Squid's Avatar
Im going to be picky: if its new I will take it, if not Im going to have to pass. Thanks for your offers Partsman.
Old Jan 28, 2012 | 06:52 PM
Partsman's Avatar
no problem......I think at the dealer they are about 20 bucks give or take a few....good luck
Old Jan 28, 2012 | 08:06 PM
Squid's Avatar
I talked to the VERY helpfull Douc.. I mean guy at the parts dept. over the phone and he said that they couldnt take it back beucase I used it and that I sumberged it in fuel. I went on to explain to him that this was the only way to see if worked properly, yada yada yada... Now when I return the part on Tuesday I have to talk to the parts manager and explain my case. Not to worry though, I know I'm in the right.
Old Jan 28, 2012 | 08:59 PM
Was the valve in a sealed bag when you bought it?
Old Jan 28, 2012 | 10:28 PM
Squid's Avatar
Yes it was. I am 99% sure that it was not me. After using the Carb Set-up thread that you posted I remeber how sensitive the valves are to get in thier seat with out binding or falling out so I took extreme care. I looked around and the mouth where the seat is recessed into is smooth and nothing that could cut it. The bag that it came in has no cuts in it either, except for where I used a knife to open it with. Yes the valve was at the opposite end of the bag when I cut into it.
Old Jan 28, 2012 | 10:33 PM
Squid's Avatar
Thanks, The guy I bought the bike from works at Corprate, should be in the mail by tuesday and overnighted intime for my ride on friday.
avramd
Oct 28, 2009 09:31 PM
avramd
Oct 26, 2009 03:14 AM
avramd
Oct 25, 2009 11:26 PM
avramd
Oct 25, 2009 10:48 PM
lowell
Jun 7, 2009 08:19 PM
