WTF???? Died in flight friday night
Old Aug 21, 2007 | 08:44 AM
j_frank's Avatar
j_frank is on a distinguished road
Hey all, I'm kinda stumped. After a 45 min ride last friday she died in a parking
lot pulling into a spot and wouldn't restart, clock went dead, and got 2 clicks
from the ignition switch. After pushing into a spot and eating dinner (30-40
minutes later) started up and rode home w/ my fingers crossed. The clock
reset to zero and I noticed that the cluster was dimmer than normal. Any
help is greatly appreciated
Old Aug 21, 2007 | 09:36 AM
superbling's Avatar
Your charging system is suspect. Usually it's the r/r (regulator/rectifier) but it could also be a bad battery or stator. If you don't have the manual, download it from here and do the tests.
Old Aug 21, 2007 | 10:36 AM
Hawk9807's Avatar
Moderatio est Figmentum
Hawk9807 is on a distinguished road
Had a similar issue a couple weeks ago. Stopped to get gas, tried to restart and nothing. Did get a couple clicks but that was it. Ended up the positive battery cable had vibrated loose. Don't forget to look at the simple things, they have a tendency to bite us all from time to time.
Old Aug 21, 2007 | 04:14 PM
KC-10ENG's Avatar
Mine has done the same thing and it was a bad battery! So I went to Walmart and got a new one! On top of that they have a core charge
Old Aug 21, 2007 | 09:02 PM
j_frank's Avatar
Checked the battery, was replaced earlier this year, need to borrow a multimeter from one of the techs I work with. I'm leaning towards the
r/r but I can't find specs or the test procedure in the forum for the
stator or the r/r
Old Sep 25, 2007 | 02:28 PM
scottiemann's Avatar
I took a 6 hour ride from my school in PA to my home in MA when i got off the last highway i pulled into the gas station to fill up and right before i stopped moving it died...checked everything and turned out to be the fuse in the battery disconect cable...
Old Sep 25, 2007 | 08:40 PM
Sgt Rock's Avatar
+1 on te R/R
Vegiepower
Jun 2, 2015 10:51 PM
haknslash
May 16, 2008 04:13 AM
lazn
Mar 17, 2008 11:38 AM
Ogre8472
Apr 18, 2007 04:37 PM
spEEdfrEEk
Jul 16, 2004 05:35 AM
