Won't restart when hot
Old Feb 3, 2009 | 06:03 AM
wasmeneh's Avatar
wasmeneh is on a distinguished road
May go look at a Superhawk that a guy has for sale . He says it runs fine but if you turn it off it won;t restart when hot. Will; restart after it cools... Sounds like a starter issue to me.. heatsink in the starter. Anybodu got any ideas or should I skip it.
Mike
Old Feb 3, 2009 | 07:40 AM
motokraft's Avatar
motokraft
motokraft is on a distinguished road
hi
hi im only a newbie here , but in my experiance this is usually a symptom of low compression as a result of tight valve clearances / worn piston rings or badly pitted valve/ seats , could be cheap to fix could be expensive .
bike would have to be cheap (imo )
best of luck with it
Old Feb 3, 2009 | 08:45 AM
RickB's Avatar
kinda sounds starter related as well, a bad armature could cause that symptom.
Old Feb 3, 2009 | 09:13 AM
Won't start....? Will it not turn over, or will it turn over and not fire?
wsharpman
Jul 4, 2012 02:31 AM
johnnyhonda
Jul 26, 2010 01:53 AM
joe6pack
Jun 20, 2010 07:04 AM
Vega (streetfighter)
Sep 4, 2008 11:54 PM
wardo996
Apr 26, 2007 08:43 AM
