Will shimming my carb needles fix this?
My bike runs great and I'm really happy with it...except for one minor annoyance -- popping on deceleration. Some people like it but I don't, I want it to sound nice and smooth when I'm off the throttle and decelerating. The mufflers had a pretty hardcore bafflectomy done when I bought the bike but everything else is stock (new air filter and plugs).
It idles great, starts easy, runs to redline without a hiccup, but has the decel problem. I've already flipped the reed in the PAIR system and that helped some but it's still doing it.
I have been researching and think that maybe shimming the needles would be good and might surprise me with some more low/mid range power I didn't know I had as well. But then I read some people say this is a good idea for the popping and then some people say that shimming the needles is only good for 2000-3000RPM and 1/8th throttle. So I'm afraid I'll not only waste my time and not fix the decel popping and then mess up how well the bike runs now.
I did check the exhaust and I don't believe it's leaking. I tightened up all the bolts and the nuts on the header pipes. The exhaust gaskets seem to be in good shape. Did a quick once over of all the vacuum lines with I installed the manual CCTs in the Spring and didn't see anything.
Yeah I don't think it needs anything major like a full jet kit. Just a little tweak whether its pilots or shims. Right now I'm fighting myself between even doing either one today because I could use that time to ride!
