VTR Fork Socket Bolt Spinning with Oil Lock Piece
Old May 8, 2010 | 02:33 PM
fred's Avatar
Mid-level Member
fred
Unhappy VTR Fork Socket Bolt Spinning with Oil Lock Piece
hi.
i've heard of this happening to other people and felt very sorry for them, but it never happened to me after 3, or so separate fork disassemblies until now.
i compressed that fork with all its innards about as far is it will travel and that socket
bolt just spins when i pop the drill with hex bit on it.
does anyone have a crafty, inventive method for getting out of this problematic situation without resorting to distruction of the fork slider?
thanks!
--fred
Old May 8, 2010 | 02:35 PM
Are you referring to the bolt on the bottom of the fork leg?
Old May 8, 2010 | 03:09 PM
If you are talking about the bolt at the bottom like inde said, there is a easy trick... Put the fork back together and loosen the bolt before you disassemble it... But that might be too easy... I always do that to keep this from happening...
Old May 8, 2010 | 03:36 PM
autoteach's Avatar
impact on an assembled fork, using the start up torque of the gun (not constant running) which capitalizes on the static friction levels(of the interior components) which are almost always higher than the dynamic friction levels.
Old May 8, 2010 | 03:37 PM
mboe794's Avatar
Put the fork back together as stated by Tweety. Then toss the drill and use a big impact wrench on it.
Edit: autoteach beat me to it.
Old May 8, 2010 | 04:02 PM
Yup. +4
If you're using an air impact gun and it's still turning without coming out, compress the fork as much as possible, remembering of course to protect the top with a few layers of rags or better.
Old May 8, 2010 | 05:22 PM
residentg's Avatar
like every one else said...
Old May 8, 2010 | 05:51 PM
fred's Avatar
Mid-level Member
fred
cool, thanks for all the replies!! i don't have an impact wrench...
i'll try and find one to borrow tomorrow.
i did get the first one out. i think after enough fork oil soaked on the threads it loosened. and i did some lateral torque with my drill and backed it out. the other one is being a bit more stubborn. i'll use a bit less red locktite when i put 'em back together them time!
Old May 8, 2010 | 05:58 PM
Use the loctite... It's good practice not to loose bolts that hold important stuff when on the move...
But like I said, break the bolts loose before disassembly next time... If that's step one, you will have an even better chance than after making them spin and then doing the whole reassembly to get them loose...
Old May 9, 2010 | 12:55 PM
fred's Avatar
Mid-level Member
fred
well, i got the impact driver... a little bit late, i'm afraid. i have the fork compressed very far with the fork slider in a vice and the hex bolt won't come free from the compression valve body. it just spinds no matter what unmentionable angular torque i apply to it. luckily, since i originally rebuilt these from a front end i'd picked up on ebay, i have a spare lower fork case for whatever side is stuck. i guess it's time to pull out the angle-grinder. this should be fun. maybe i'll post a picture.
Old May 9, 2010 | 01:59 PM
residentg's Avatar
an air driven impact driver, not the type that you hit with a hammer - correct?
Old May 9, 2010 | 02:37 PM
fred's Avatar
Mid-level Member
fred
the 18V battery verion of an air driven impact driver. yes.
Old May 9, 2010 | 04:19 PM
autoteach's Avatar
HEY, stop, no grinder!!!!
If you cannot get the screw out, the easiest way (and I have done this at least 5 times in the last three years on forks) is to drill the bolt. If you use a drill bit that is slightly larger than the threads/smaller than the head of the bolt, you can drill until it pops the head off. Once you do that, you can remove the lower leg and get the bolt out of the inner piston. dont grind!!!!
Old May 9, 2010 | 04:35 PM
residentg's Avatar
OK - just making sure
Old May 9, 2010 | 05:09 PM
fred's Avatar
Mid-level Member
fred
i wish i'd read this a couple hours ago. i've never run into this problem before and since i had a spare lower, i went ahead and did it the hard way. next time i'll have an impact wrench and if this happens i will take your advice.
thanks,
--fred
Old May 9, 2010 | 05:13 PM
autoteach's Avatar
I wish I had seen your post about the grinder prior to you starting. Oh well, life's little adventures...
salmanilla2000
May 9, 2011 12:05 PM
salmanilla2000
Apr 27, 2011 10:41 AM
AngryOlaf
May 25, 2010 09:39 AM
HawkRider98
Sep 10, 2008 09:07 AM
HawkRider98
Aug 13, 2008 06:24 PM
