VTR being a pain in the ass
Old Dec 30, 2008 | 05:26 PM
Collywog19's Avatar
Collywog19 is on a distinguished road
VTR being a pain in the ***
Hi guys. Im still having problems with my VTR
been off the road for months now.
Its running better than it was.
Now i go to pull away, it pulls away fine, but when at about 3k it drops to 1 cylinder. Just before i put the bike away for the past 3 month, thew bike was running till 3k, dropping onto 1 cyl, then after 7k rpm both cylinders would work and it would fly lol.
I changed, both cdis, swapped coils over (still same cylinder that was dropping out after swap), 2 brand new iridium plugs. Vaccum hose is on the right bit of tank.It ticks over lovely and sounds beautiful lol.
Both ht leads and caps changed.
Checked timing tonight and timing is fine.
Any other ideas of what it could be? Pulse generator?
I dont have the tps plugged in as i broke it when i took carbs out to clean. But ive been told it makes no diff and should definetly not make it run like this, in anycase it ran liek this before i even touched carbs.
thanks guys
Colin
Old Dec 30, 2008 | 06:13 PM
Water in the fuel?
Old Dec 30, 2008 | 06:31 PM
AZZKIKER's Avatar
My money is on the timing.
Old Dec 30, 2008 | 06:34 PM
Nah! Junk in the fuel.
Old Dec 30, 2008 | 06:46 PM
Check for a hole or cut in the carb diaphragms. Sounds like one of your slides isn't lifting.
Old Dec 30, 2008 | 06:50 PM
Flush your entire fuel system. Chas did this to his CBR and it was a bitch to clean up. Check your throttle cables. Make sure everything is rotating. Check for air leaks. If you still have the cough, sputter, die thing going on it is water in your fuel. It's that time of year. Make sure you are going through an adequate warming cycle before you romp on the bike. I don't move my bikes until I see the needle come off "cold". The tires are next. Let's be careful out there this time of year. Lots of guys go down to cold tires and comprimised road conditions.
Old Dec 30, 2008 | 10:12 PM
divingindaytona's Avatar
Remember stock is BAD!
This may be related or may not, but it is worth looking into. Check that the hoses that go to the tank are on correctly.
I once confused two lines, (I was in a hurry) and had somewhat similar results.
She would pull fine up until 3 or 4K then fall flat on her face, then pick up again at about 7 or 8K. Swapping the two hoses cured the problem. I never made that mistake again!
Old Dec 31, 2008 | 05:44 AM
Collywog19's Avatar
Thanks for your help so far guys.
The thing is the bike had been riding fine for 3 month, then one day out of the blue, while i was riding it, this all happened.
Its deffo not water in the fuel as it was bone dry weather when all this started to happen.
Also the vaccum hose is on the horizontal pipe, which is right as it lets fuel out really good. But id never touched any of this once it started to happen. As i said it just happened one day.
Thanks
Colin
Old Dec 31, 2008 | 05:48 AM
Collywog19's Avatar
Hmmm. You could be onto something here.
I tell you why.
When this all started to happen, i took airbox apart and one of those pesky triangle shape kinda things had came off ( as they usually do ) and was in the trumpet for the front carb, im pretty sure its the front cylinder thats causing all the aggro, so could this have caused damage to the carb etc?
Thanks again guys
I just want this thing back on the road, as riding my Cagiva Mito 125 2t is just not so much fun with passenger haha.
Colin
Old Dec 31, 2008 | 07:30 AM
Little_Horse's Avatar
2nd mouse gets the cheese
the trianlge thing (secondary filter) won't cause any damage, don't ask me how I know, but that doesn't mean its not slides still check em.
Old Dec 31, 2008 | 07:36 AM
Collywog19's Avatar
Well if this rubber bit blocked the inlet and the carb was desperatly trying to suck air in would this not have damaged it?
Im at a loss here, there really isnt much else for me to check
thanks
Col
Old Dec 31, 2008 | 08:25 AM
hawxter996's Avatar
ole dirty bastard
have you recently installed a jet kit?
Old Dec 31, 2008 | 08:32 AM
Collywog19's Avatar
I hadnt touched the bike at all guys. It just happened while riding
Old Dec 31, 2008 | 08:43 AM
hawxter996's Avatar
ole dirty bastard
front or rear cylinder?
you said bike had sat.
pull your carbs inspect and clean
gunk somewhere is my guess
Old Dec 31, 2008 | 08:50 AM
Collywog19's Avatar
right guys, checked carbs again and the rear carb the needle circlip had fooked and the needle was still sitting in the hole not lifting when needed.
So i put it on middle notch with new circlip as theres no info.
the bikes running MUCH better.
But if kept at say 6 k rpm, the front cylinder kind of knocks, misfires. Put choke on and it runs ALOT better than without.
Im going to take it for a run tmoro and see what its like.
Also i didnt notice the needle before, so whether this is a new thing or its been the problem all along i dont know, but there deffinetly is something up with the front cylinder.
Thanks
Colin
Old Dec 31, 2008 | 09:32 AM
hawxter996's Avatar
ole dirty bastard
Thanks
Colin
front cyl. sounds like it could be too lean.
sounds like there is a jet kit installed also.
try raising the needle in front carb also.
and check setting of mixture screws
usually about 2-1/2 turns out,correct guys?
Old Jan 1, 2009 | 07:47 PM
Mixture screw setting depends on a couple of things: filter (stock or aftermarket), exhaust, and elevation. 2.25 turns works for me.
Old Jan 3, 2009 | 05:35 PM
sparkyharley's Avatar
sparkyharley is on a distinguished road
check simple things first
Check your plug wires and make sure one is not vibrating off as the RPM's rise. I had a similar problem and only after much anguish did I discover the front cylinder plug wire was not secure.
After using pliars to tighten up the connector I have not had any more issues.
SWP
Old Jan 4, 2009 | 12:21 PM
Collywog19's Avatar
Its had new ht leads and caps, and they are very secure, But ill double check
Col
Old Jan 7, 2009 | 06:39 AM
Collywog19's Avatar
Well............................
Fitted a second hand set of carbs with a good TPS. all connected up, ran rough, then fiddled with choke etc.
Heres a pic of it today
she runs just as before w00000p!
So excited, i took it to dealers as i needed 2 rear bulbs. hehe, Love it
Cheers for all your help guys!!!!!!!
Colin
Old Jan 7, 2009 | 11:40 AM
jbaxx's Avatar
Honducati
Bike looks great! Glad she's up and running.
Old Jan 14, 2009 | 04:21 PM
Gtrain00's Avatar
Gtrain00 is on a distinguished road
good to hear you got it running.. that is one nice looking superhawk.
Old Jan 14, 2009 | 04:33 PM
badboyrr's Avatar
Real glad you got it sorted out. Enjoy.
Old Jan 14, 2009 | 05:33 PM
g_clarke_2008's Avatar
Glad it's running, nice looking bike. I noticed that's a firestorm not a superhawk, same as mine but wrong color. Where are you located?
Old Jan 16, 2009 | 06:10 PM
Collywog19's Avatar
Im in the UK.
Its still all running fine
Passed mot, got it taxed, and insured. New front tyre on and she rides a dream.
Thinking of geting some 6 spoke rims now.
Col
smokinjoe73
Mar 28, 2011 08:06 AM
ttocsmai
Aug 2, 2010 12:01 PM
blupleous
Aug 30, 2008 07:40 PM
Ysabel
Feb 6, 2008 07:32 PM
soopahok996
Aug 15, 2006 05:05 AM
