turn signals inop when cold
Old Oct 29, 2013 | 09:20 AM
rnb's Avatar
rnb
rnb is on a distinguished road
Hi everyone. Need help with turn signals. If it is above 60 degrees the signals work fine under 60 degrees they wont work at all. I am out of ideas, your help will be appreciated. Thanks and ride safely.
Old Oct 29, 2013 | 10:19 AM
Letsrideinsc's Avatar
Letsrideinsc
I have the same problem, but they work, just delayed in operation. Usually start blinking about when I'm already in the process of turning. I am going to order a new relay next time I buy some parts to be safe.
Old Oct 29, 2013 | 10:37 AM
Hey Rick, funny you posted this today. I rode the Hawk to work (very low 30's) this morning and for the first time, mine delayed just like letsride mentioned. I thought maybe it was my thick cold weather gloves that I haven't wore in a while. I'm pretty sure I toggled the blinker though. I quickly gave it a second try because I was getting close to my turn and they eventually lit. Curious to hear opinions.
Old Oct 29, 2013 | 12:07 PM
Disassemble the turn signal switch completely and clean the old lube out and re-lube with a dielectric grease. You'll see why they're delayed or don't work (really long delay) in the cold with old sticky lube when you get into the switch. I had the same issue in early spring. It's all better now that the 14 year old lube is gone. I think this was just discussed in another thread.
Old Oct 29, 2013 | 03:37 PM
Letsrideinsc
I just bought me a tube of dielectric! Thanks for the suggestion! Will rebuild it this weekend.
Old Oct 29, 2013 | 04:03 PM
Original owner of your 99 Superhawk Letsrideinsc? That's cool.
Old Oct 29, 2013 | 07:55 PM
Under 60? Wait til you try them at like 9F. I have gone through this. Spray with contact cleaner and you should be fine. Then combo of contact cleaner and "wire dryer".
If you ride colder you can try the dielectric grease thing but didnt help me tons.
One trick is to active the turn sig then push up on the lever. Beyond that, I only solved the problem by buying a newer set of switch gear. (didnt have patience for more dismantling/cleaning)
Old Oct 29, 2013 | 08:55 PM
Joe, did you ever disassemble and clean the switch mechanism? It's a pain, but mine was full of goo.
Old Oct 30, 2013 | 09:41 AM
rnb's Avatar
rnb
Thanks guys. I will try cleaning and putting in dielectric grease. I knew someone on the forum could help.
Rebirth98
Oct 10, 2013 09:12 PM
johnclopp85
May 13, 2009 07:20 AM
wyldryce
Jun 25, 2007 05:09 PM
Cheesedrug
Dec 22, 2006 05:07 PM
