Turn signal quandry
Old Apr 30, 2013 | 06:47 PM
GlockPointer's Avatar
Connie Demico does toad?
Turn signal quandry
I had four cheap incandescent turns sigs that flashed at a normal rate. Then I went with OEM style relacements on the front because I'm not drilling holes into new factory fairings. I have the plugs that go on the original sigs and have used them to hook up several different kinds of cheap incandescent sigs over the years.
With the new OEM style sigs hooked up three-wire style all sigs act as running lights and blink real fast. With the new ones hooked up two-wire, no running lights but they still blink fast.
Gets better. Either + sig wire hooked up to the blinker flashes the same filament. Either + sig wire hooked up to the running light illuminates the other filament. How the hell is that possible?
On a related note; I'm in the market for some factory turn sigs.
Old May 1, 2013 | 07:51 AM
Yeah, I haven't figured it out either.
Old May 1, 2013 | 08:37 AM
Are you using 23W incandescent bulbs?
Old May 1, 2013 | 01:23 PM
The new ones are 23w, the old ones are 21w. The rears have a little elfs hat 23w. The old combo blinked normaly.
Old May 1, 2013 | 01:47 PM
RWhisen's Avatar
Former Superchicken Owner
This will fix it.
HighTechSpeed - motorcycle high technology
ali_squidz
Sep 13, 2007 09:56 PM
J.J.
Sep 15, 2006 06:27 PM
zimm
Sep 6, 2006 02:07 PM
cb21983
Mar 21, 2006 05:59 PM
hawkman
Mar 7, 2006 07:52 AM
