trouble shifting... need help!
Old Sep 22, 2005 | 03:09 AM
apbrian112's Avatar
apbrian112
hey guys, i need some help here. well, as i was coming home i tried to downshift from 4th to 3rd but the transmission just would not budge. when i got home i managed to shift the bike into neutral (with my hand). the bike will UP shift easily but down shifting is quite a chore. i can't get the bike into 1st, the furthest it'll go down is into N. has this happened to anybody before, it happened without warning. thanks for any help you can offer.
-brian-
Old Sep 28, 2005 | 12:08 AM
standzchop's Avatar
standzchop
Re: trouble shifting... need help!
a wild guess...bleed your clutch slave cylinder ....if you have old fluid and or air in your clutch, you won't be able to spread the disc's apart far enough to shift....hope this helps.....standzchop
Old Sep 28, 2005 | 05:16 AM
woodman's Avatar
woodman
What he said
Old Sep 28, 2005 | 08:09 AM
jschmidt's Avatar
jschmidt
Also check the clutch plates for warping. Other than that, your options are expensive.
Old Sep 28, 2005 | 09:49 AM
apbrian112's Avatar
apbrian112
i totally forgot about this post. well the next morning (in some daylight) i inspected the shift linkage and found that i couldn't down shift because the end of the linkage assembly was hitting the rubber exhaust bung directly behind the linkage. i just took the linkage off of the spline and rotated it a couple of notches and everything is tip top. i'm guessing the previous owner had adjusted it that way to have a more aggresive shifting stance. (?????) well thanks for the replies guys.
-brian-
Old Sep 28, 2005 | 09:55 AM
jschmidt's Avatar
jschmidt
-brian-
Ho, Ho, Ho!
Old Sep 28, 2005 | 10:12 AM
apbrian112's Avatar
apbrian112
the only thing i was wondering was, how did it suddenly happen... i rode it for 2-3 weeks without any problems and then it just happened.
Old Sep 28, 2005 | 12:30 PM
superhawk22's Avatar
If the pinch bolt got loose and you down shifted hard it could've moved on you. I lost my pinch bolt once when I went off the track! The vibration loosened it then slamming it down caused it to pop off.
Hawkrider
Apr 11, 2013 04:52 PM
timc
Apr 28, 2007 09:30 AM
The Hawk Guy
May 2, 2006 04:55 PM
mks8882
Jun 1, 2005 11:04 PM
MikeD
Mar 8, 2005 10:34 AM
