Track Bike cooling
Old Apr 26, 2009 | 08:46 AM
budman's Avatar
budman is on a distinguished road
Track Bike cooling
My SH is a track bike and will never see the street again. I want to remove the left radiator and just run the right with the fan. I would probably put a switch on the fan for waiting on pit lane. Any thoughts.......
Old Apr 26, 2009 | 08:50 AM
hawxter996's Avatar
ole dirty bastard
two words ,over and heat.
not a good mod for the track.
you want more cooling not less.
Old Apr 26, 2009 | 09:08 AM
if track days are the sole use for the bike, ditch the fan, it will help improve airflow through the right rad, and hence improve the cooling. You may also want to look at the possibility of putting on a larger oil cooler to help further.
Old Apr 26, 2009 | 09:18 AM
JamieDaugherty's Avatar
+1
Old Apr 26, 2009 | 04:52 PM
Hotbrakes's Avatar
Yeah, mine always runs hotter on the track. Heat robs power. Are you trying to save weight or something? Another oil cooler would be nice. I agree with removing the fan too to improve airflow, but watch that guage, especially if you are running straight water.
Old Apr 26, 2009 | 04:56 PM
RymerC's Avatar
RymerC
Are you guys overheating? Even after 30 min sessions I don't get close to halfway. I don't know what that translates to in F degrees though. Maybe I need an oil temp gauge.
Old Apr 26, 2009 | 05:02 PM
I don't even get that hot. Even around Mid-Ohio in August! In fact, my bike runs at the first line just like it does on the street - no different. When you come off the track if you sit on hot pit lane with it running too long the fan will come on, but that's no big deal. While I'm moving everything is a-ok.
Old Apr 26, 2009 | 07:29 PM
gboezio's Avatar
On the track, I'm at 98°C all session long and I have two rads.
Old Apr 26, 2009 | 08:10 PM
dshakes's Avatar
dshakes is on a distinguished road
mine gets hot if i sit in slow moving trafficor if i ride hard. Hovers just low enough to keep the fan off. does kick on time to time though. bafflectomy make it run warmer?
Old Apr 27, 2009 | 06:56 AM
Red_Liner740's Avatar
aftermarket pipes or bafflectomy makes the bike run leaner = hotter temperatures...
Old Apr 28, 2009 | 10:04 AM
dshakes's Avatar
Any suggestions to run a little cooler? It was 85 yesterday and in traffic it runs warm-fan on here and there-even cruising at 35 or so it runs warm. Hate to see when its 95!
Old Apr 28, 2009 | 10:07 AM
That doesn't sound right. At any moving speed your fans should not be running. My bike doesn't change at all, even at 100 degree temps. It sounds like your thermostat isn't working right.
Old Apr 28, 2009 | 01:33 PM
budman's Avatar
I ran my hawk on the street for 3 years befor track duty only and I dont ever remember the fan comming on. I remember testing it several times just to make sure it worked. BTW bigger oil cooler shoud be here by fri
Old Apr 29, 2009 | 01:18 PM
dshakes's Avatar
Suggestions on testing the problem and a solution? Still a novice in the tech department. How hard of a swap would that be?
FTMS
May 4, 2012 08:25 AM
Otto Man
Sep 1, 2007 06:29 PM
seaton001
Apr 5, 2007 01:54 PM
dpenix76
Mar 29, 2007 09:27 PM
EngineNoO9
Apr 24, 2006 12:46 PM
