TPS Adj
Its set once and done.
I do have a pigtail with OEM plugs so i can meter it easily.
If you want to really play with TPS settings, you could easily set the TPS at a given point and use a variable resistor or pot to "adjust"
If you found 2, 3, 5 settings that worked for Rain, track, street it also would be easy to build a multi position switch select the various settings.
I don't think he wants a variable unit. But to tune it where you think it's optimal, may take a few times. I'm going to try 520 next, might not suit me. Time will tell.
So isn't there one optimal point performance wise? Meaning you aren't drawing different maps or hp curves, its either optimizing power or not. So in that way I could see maybe softening it for rain but other than that, what did you like or not like about the different settings? Is it different delivery curves?
So I am dealing with carb farts on the front carb too. I recently synced and then did tps. I am still getting the CFs even after putting a long trumpet on the front carb.
Pretty mad since my hawk rode like silk the whole rest of its life and now I'm chasing gremlins. Recently I installed the CCTs and accidentally pulled the front one while not at TDC. Only turned motor by hand at that point but my garagemate swears we coulda tweaked the valves. (leakdown test OTW).
Wolverine were the carb farts frequency changing with temp? Mine changes drastically with temp. At higher temps its less frequent.
I feel there is a "Sweet Range" 490~ 550 or so.
I do not believe all bikes have the same dial in spec..... of XXX ohm
Nor do I feel above 500 works better on my two SH, nor the others I service, but can for sure see it works well on someones else bike for how they want to use the bike.
But every bike is a bit different, tuned different, used differently.. Ones persons "Its jerky, its too hard to roll on gas smoothly" is another persons "Crisp, works perfect for me"
Out of curiosity I changed my 2001 SH to 530 last night and will ride it today. I changed another SH I have in the shop to 500 and will ride it today as well if the rain holds off.
If you have any doubts, simply change it to 520-530 and see if it improves.
I use mine for commuting to work, scenic touring, track days, flogging around local roads.... It has done it all, happily, till this.
I get what you are saying about individual opinions Erik. When we throw a leg over, everyone senses are different. After 10+ years, I'm pretty well in tune with the old girl. She was **** for all those years till I went in and changed a few things. I thought initially that the fuel screw must have a different profile or something. Never thought the tps would have a profound effect on the bike. Boy was I wrong!
