setting the TPS
Old Dec 17, 2008 | 03:40 PM
zixxer's Avatar
zixxer is on a distinguished road
setting the TPS
hi guys, is it possible to set the TPS correctly with the carbs out of the bike?
Old Dec 17, 2008 | 06:04 PM
bristunt's Avatar
bristunt is on a distinguished road
yes, same methodology as "on bike"
Old Dec 21, 2008 | 09:26 AM
Hawknut's Avatar
Hawknut
I would say no.Anytime you move the throttle the TPS moves and changes it's output value.So unless you know your idle speed is set were it is supposed to be the setting you make will change if you have to reset your idle speed.I don't believe it says this in the manual but it will change however little.
Old Dec 22, 2008 | 02:56 AM
gboezio's Avatar
I did mines carbs out, setting the TPS to 500 ohms will retard the timing specially at lower RPM lowering efficiency, but will smooth out operation.
I will revert to a more aggressive setup this summer, more like stock.
jon1475
Apr 29, 2013 05:33 AM
macworld
Jun 20, 2010 09:38 PM
Alpar
Aug 30, 2007 07:09 PM
mikecronis
Aug 17, 2005 05:58 PM
ClevelandSuperhawkRumble
Apr 21, 2005 01:44 PM
