Timing jumped, possible damage.
Old Oct 11, 2011 | 12:55 AM
waltr's Avatar
Not Realy A Squid
waltr is on a distinguished road
All right everyone looking for some advice.
I am looking at a 99 that needs some valves replaced.
After questioning the current owner it sounds like the cam timing jumped. I know about the CCT issues and suspect that is what happened. The current owner was told it would cost $1500 to fix it.
I am fully capable of fixing this myself and am not the least bit afraid of the job.
Now for my questions. What is the normal damage when this happens? I know the valves but do the guides get damaged? What about the piston? Does it get ruined by the valves? Does the rod ever get damaged?
I do not have the bike so I am trying to get these answers to decide if it is worth it and how much I should offer.
Thanks for the help.
Old Oct 11, 2011 | 01:52 AM
Valves in the effected head.
So you’re likely to need, 4 valves, valve seals, 4 sets of cotters, ,, me Id replace the springs as well.
Then a head gasket, set of MCCT’s, coolant and oil.
It’s possible a valve guide can be damaged when the valve is bent, and if the timing caused a valve / piston crash at higher RPM, the piston can be damaged as well.
If I were bidding on a used bike having this issue.. I would assume the worst, and price the bike accordingly
Old Oct 11, 2011 | 02:17 AM
Wicky's Avatar
See if you can locate a second-hand (front?) head and transplant that on.
FRONT CYLINDER HEAD COMPLETE
Old Oct 12, 2011 | 08:28 AM
msethhunter's Avatar
Depending on how bad the damage is to the pistons, you might want to replace them as well. It can create a pressure spot in the piston, as well as a place for a crack to start from, and well, I'm sure you can imagine the damage when a piston comes apart at 9500rpm.
Old Oct 12, 2011 | 08:57 AM
Wicky's Avatar
Engine parts for sale
https://www.superhawkforum.com/forum...ts-more-26680/
Hangfly
Jul 16, 2015 07:18 AM
tmoyer690
Apr 3, 2013 01:02 AM
SuperHawkins
Jan 5, 2007 07:01 AM
Rufion
Apr 16, 2006 12:45 AM
Jason C
Sep 18, 2005 04:08 PM
