Are these the stock forks
Old Nov 15, 2017 | 02:36 PM
Mvanriel60's Avatar
Mvanriel60 is on a distinguished road
Everyone is saying the front should have suspensions settings on them ... mine on the other hand 0....
Old Nov 15, 2017 | 03:42 PM
matt365's Avatar
Forks are stock, fork caps aren't. They should have preload adjustment with the compression adjuster in the center.
Old Nov 15, 2017 | 03:58 PM
Mvanriel60's Avatar
thanks so much.. Do you know if I buy the fork caps with preload and compression will they work from direct bolt on or is there an assembly that goes with them
Old Nov 15, 2017 | 06:59 PM
You may have missing parts and pieces when you open up those forks. Just food for thought. If PO butched the forks with the wrong caps, no telling what else was done to the bike. Be careful!
Old Nov 16, 2017 | 12:38 PM
Looks like someone tempered with the forks...
Old Nov 16, 2017 | 03:08 PM
Is that a US spec bike. If not what market did it come from?
Old Nov 17, 2017 | 08:05 AM
fabiostar's Avatar
the lowers are standard storm, the uppers and/or the caps could be from a VFR750..not RC30 but the normal VFR.
Old Nov 18, 2017 | 01:03 AM
Cadbury64's Avatar
VTR virgin
I'd say Fabio is about right. Which begs the question why? My guess is the original uppers got badly bent and someone swapped in the tubes, cap and dampers from the VFR. If you wanted to, you could buy some lightly bent VTR forks and take the caps and dampers from these and swap them back in, in my experience the dampers and needles should survive undamaged as long as the bend is small. Or contact a suspension expert (e.g. Daugherty Motorsports) and but a cartridge insert from him.
NZSpokes
Jan 23, 2015 07:57 PM
VTRsupersport
Feb 29, 2012 05:09 AM
spdrcr
Aug 3, 2007 03:46 PM
flyguyeddy
Apr 18, 2007 01:57 PM
steve365
Nov 7, 2005 04:27 AM
