Swing Arm Pivot Bolt CC "Tunnel" Greasing
Old Jan 2, 2014 | 01:30 PM
Has anyone done so or know any reason it should not be done?
When I removed the swing arm I discovered corrosion on the pivot bolt and am strongly considering filling AMAP the "tunnel" the bolt passes through in the rear of the crankcase. The tunnel is sealed off from the transmission "bay" and water and debris appears passes by the plastic bushings on each side of the crankcase tunnel. You'd think filling this cavity with waterproof grease would encapsulate and minimize corrosion development on the bolt.
I do not want to remove the plastic bushings for fear of cracking them but they inhibit access and dirt egress into / from the tunnel.
Has anyone removed them and then successfully reinstalled a "used" set" of these bushing, and if so how?
Old Jan 2, 2014 | 01:36 PM
Wicky's Avatar
It's a good idea to check and grease swing arm and linkage check bearings esp if used all year around.
www.vtr1000.org • View topic - *** IMPORTANT*** Swingarm and linkage bearings servicing***
Old Jan 2, 2014 | 02:09 PM
That goes without saying along with the shock eye bearings (my Penske 8981 is at TS&E for a major rebuild & update); a new chain and sprockets will round out the rear drive and suspension refresh.
I'm talking about where the SA pivot bolt passes through the rear of the CC !
Attached Thumbnails Swing Arm Pivot Bolt CC "Tunnel" Greasing-vtr-rr-cc-sa-pivot-bolt-tunnel-tc.jpg
Old Jan 2, 2014 | 04:58 PM
I'm also thinking I could drill a small hole in the rear of the crankcase into the swing arm pivot bolt tunnel in an accessible location, tap threads in it and install a Zerk fitting, and pump grease in easy-peasy. No?
Old Jan 2, 2014 | 05:15 PM
You could..but unless your somehow forcing water and mud in there (like with a pressure washer, or off road use) .. I would think a liberal application of a water proof grease (I like BelRay or Maxima) would do fine for a dozen years or so.
Old Jan 2, 2014 | 05:19 PM
If you decide to install a grease fitting.. drill the through hole (grease channel) fairly small say 2mm, then drill a shallow hole needed for threading, and use a plug tap.. No need for a large hole all the way through the case.
Old Jan 3, 2014 | 07:03 PM
Thanks Erik.
Most Zerk fittings require at least a 3/16" deep hole if not more for the threads to bite and I estimate the crankcase wall thickness to not be much more than that in the "zone". If I do go b'Zerk I'll pick a spot with minimum structural implications.
As to water and muck finding its way in there, I never use a pressure washer but after 15 years and 82k miles (thousands in the rain unfortunately), I did find crud in there and the pivot bolt had lost its plating in spots with very light corrosion.
Old Jan 4, 2014 | 03:25 AM
Thanks Erik.
The case wall thickness looks to be about 7~8mm where the swing arm pivot bolt goes through.
Grease fittings can be press in or tapered thread or straight thread
An M6 tapered thread zerk has about 7mm overall thread area.. and it only needs about 2/3 that to be threaded in the base material.
A M6 self threading flush style has about 5mm of thread area and would easily work in this application
An M6 self threading straight grease fitting has 5.5mm of thread area, and again would work perfect in this application
Attached Thumbnails Swing Arm Pivot Bolt CC "Tunnel" Greasing-case-half.jpg   Swing Arm Pivot Bolt CC "Tunnel" Greasing-case-half-top.jpg   Swing Arm Pivot Bolt CC "Tunnel" Greasing-fitting-flush.jpg   Swing Arm Pivot Bolt CC "Tunnel" Greasing-straight-self-tap-fitting.jpg
Old Jan 4, 2014 | 05:38 PM
Great Photos, were you rebuilding your own VTR?
The good old USA 1/4"-28 work too
1/4"-28 Taper Thread Grease Fittings, 1/4"-28 Zerk Fittings, Taper Thread Grease Fitting
METRIC GREASE FITTINGS | METRIC ZERK FITTINGS | METRIC GREASE FITTINGS
1/4"-28 Straight Thread Grease Fittings, Straight Thread Grease Zerks
But looking for stainless steel
[/QUOTE]A M6 self threading flush style has about 5mm of thread area and would easily work in this application
[IMG]https://www.superhawkforum.com/forums/attachment.php?attachmentid=16518&stc=1&d=13888343 96
[IMG]https://www.superhawkforum.com/forums/attachment.php?attachmentid=16519&stc=1&d=13888347 05[/QUOTE]
Attached Thumbnails Swing Arm Pivot Bolt CC "Tunnel" Greasing-h165-pt-25-28-tapered.jpg   Swing Arm Pivot Bolt CC "Tunnel" Greasing-h145cu-pt-25-28-45-unf.jpg   Swing Arm Pivot Bolt CC "Tunnel" Greasing-m5-8-45.jpg
Kendrick
Jun 11, 2014 06:55 AM
Rollin20z
Apr 9, 2012 09:07 AM
mikstr
Jan 23, 2011 08:31 AM
selztoad
Sep 5, 2006 03:33 PM
Jetfever
Jul 1, 2005 04:57 PM
