superhawk sputter???
Old Sep 19, 2007 | 06:55 PM
fatmatt473's Avatar
fatmatt473 is on a distinguished road
it starts right up idles fine revs up fast. till it warms up . when i am riding it it sputters(falls flat on its face) sputters down and sounds like its miss firing. it pops and backfires like its not getting spark then it kicks back into full power then sputters. over and over again. this is a bad situation for me.
Old Sep 19, 2007 | 07:19 PM
filter69's Avatar
Thats Mr Dill hole to you
I had one do that on a old honda was the igniton trigger, only did it after it got hot and broke down the windings cooled off all fine again...
You could get a timing light and chk to see if your timing is erratic on the flywheel on the shifter side.
Old Sep 19, 2007 | 07:32 PM
fatmatt473's Avatar
thanks i wil check into it. how much are those
Old Sep 19, 2007 | 09:12 PM
Pull out the choke a bit when the bike is warm. Does it get better? If so then you need to rejet.
Old Sep 25, 2007 | 02:27 PM
hawxter996's Avatar
ole dirty bastard
Greg,
j-bird has a couple post about his bike,not running correctly.
after looking at his post,i decided to tinker with my bike.
and found that my "coils were bad" well i pulled the plug boots off
the coil wires and found the boots themselves were no longer conductive.
i advise anyone having symptoms of bad coils to check theirs.
may not be a coil after all just a plug boot that retails for 15 bucks.
Mike E.
Old Sep 25, 2007 | 03:44 PM
ali_squidz's Avatar
thats what i was thinking, or at least a good carb/jet/filter cleaning.
Old Sep 25, 2007 | 03:45 PM
ali_squidz's Avatar
Greg,
Mike E.
you could have easily found this out by cranking the bike while its dark in the garage. you should be able to see arcing.
Old Sep 25, 2007 | 03:50 PM
hawxter996's Avatar
ole dirty bastard
no fire at plug. the plug boot has a resistor and spring inside that lead to my prob.
coil is ok.
spark check is how i found i had coil prob.
investigating led to plug boots both of them.
i would advise anyone with coil probs check plug boots separate.
Old Sep 25, 2007 | 03:57 PM
ali_squidz's Avatar
agreed but i have always found with bad wires, you can see them arc.
ideally you want to isolate each variable at a time.
Old Sep 25, 2007 | 04:05 PM
hawxter996's Avatar
ole dirty bastard
ok gotcha,but wasnt wires was rubber boot that coonects to plugs.
when you buy coil from honda boot is a serarate part.
Old Sep 25, 2007 | 04:09 PM
hawxter996's Avatar
ole dirty bastard
ok end of thread jack hope you get prob resolved.
rickchampion
Jan 1, 2010 02:41 PM
DocPigskin17
Jun 20, 2007 04:09 AM
