Superhawk spark plugs for $10?
Old Nov 17, 2011 | 11:29 AM
Matt_Hawk's Avatar
Wild Man
Why are we paying $10 each for the plugs?
I just took out the platinum ones which NGK doesn't make anymore and put a new set of Iridium ones. The bike runs the same. Perfect.
So why can't we just use a cheap copper core ones for $2?
Any plug will last 12k miles. My platinum's were pulled at 8k and they look like new. The bike is low tech so why a super expensive plug?
Old Nov 17, 2011 | 11:59 AM
Because of the limited market for the plug. It is not used in many applications.
You can try to run a cheep plug to try and save a few pennies but I have never heard of anyone having any luck what so ever with running a different plug in this bike.
Also $10 is on the high side but be happy they were $13 - $15 back in the good old days....
Also just "looking" doesn't tell you much. You need to measure the plug gap. If it is larger than spec, then the plug is worn and needs to be replaced.
Old Nov 17, 2011 | 12:06 PM
$20 every 12k miles... don't think I can afford it. May as well sell my motorcycle or find out how I can reduce this cost to 5 bucks somehow.
Old Nov 17, 2011 | 07:15 PM
1971allchaos's Avatar
Dam ! ! Your Kidding right ! ! With all the Fuel Mileage on the VTR1000F(liter bike) questions. That you haven't been able to save $15.00 in TWO YEARS for a set of plugs (2)plugs/ not four... Hell, I am glad we have these discussions..
NEXT, You will be complaining about the F'n performance of your S-hawk..
Old Nov 17, 2011 | 07:42 PM
Matt_Hawk's Avatar
Wild Man
Hey...every dollar adds up in an account over 20 years.
I checked the gap on the platinum ones = .35
The gap on the new iridium ones checked = .35
Electrode looks great.
Insulator great.
Ground strap brown with a slight white tinge.
Light carbon ring around base.
No deposits anywhere.
She's running pretty close to perfect- perhaps just a tad lean in this cold sea level air. I'll try the needles raised one click for Winter.
Meh...I wasted $20 when I didn't have to.
Old Nov 17, 2011 | 08:31 PM
GlockPointer's Avatar
Connie Demico does toad?
I however did not waste 25$. I found them at Cyclegear for 11.99 and hooted. The guy told me some newer bikes had plugs listing for 45$ a pop! I was too flabbergasted to ask wich bike.
My old plugs may have been original, gap was .040 and they were beat. Of course the bike runs way better, but now I think I feel the need for a carb balancing.
Old Nov 17, 2011 | 08:52 PM
Matt_Hawk's Avatar
Wild Man
Then you got ripped off.
Here's what I paid at motorcycle superstore...$8.99
NGK DPR9EIX-9 - Iridium Spark Plug - Street Bike - Motorcycle Superstore
I got free shipping and no tax on my order since it was $90 with other stuff.
Edit: It's funny how the single plugs are $8.99 and the four pack is $38.99.
So you lose $3 if you order four?
Old Nov 18, 2011 | 08:11 AM
ascothawk's Avatar
ascothawk is on a distinguished road
NGK Iridium plugs
I buy mine at Advance Auto parts for about $7.50.
Old Nov 18, 2011 | 08:41 AM
Wicky's Avatar
DIY - Make your own everlasting Krupa Firestorm Spark Plug
Shopping list and tools:
Bit of wire
Toilet roll tube
Solder
Sticky back plastic
File
Save those $dollars$ for fuel!
Old Nov 18, 2011 | 10:36 AM
I buy mine at a stinking Honda Dealership- for $9.99 or is it $6.66
Old Nov 18, 2011 | 10:59 AM
Well they are $7.20 at the Honda dealership I use....
Honda, ATV Parts, Scooter Parts, Motorcycle Parts,CRF,CR,MX Parts, Goldwing parts
Pos #20
Old Jan 28, 2012 | 10:04 AM
aja's Avatar
aja
Sorry to revive this thread, but does anyone know of a different plug to use? I've tried Auto Zone, Oreilleys, Napa, and a local cycle store with no luck. They all said they didn't have or know of any other plug that would work.
Old Jan 28, 2012 | 10:08 AM
There really isn't any and even if there were I would still recommend running the OE plug
Old Jan 28, 2012 | 10:11 AM
Those are DPR9EVX9. The NGK iridium plugs for the Superhawk are DPR9EIX9.
Yeah they just haven't updated their fiche..... I don't think you can even get the 9EVX9's anymore as they stopped making them when the 9EIX9's came out..... but i could be mistaken
Old Jan 28, 2012 | 10:13 AM
aja's Avatar
aja
Ya I was getting the OE number from the manual, no one carries it or has anything else that I could use (as far as they know). Are you saying the EIs can be used?
Old Jan 28, 2012 | 10:14 AM
aja's Avatar
aja
Sorry I guess I wasn't clear, I'm not looking for an alternative just because, I'm looking because I can't find the recommended plugs.
Old Jan 28, 2012 | 10:27 AM
Oh ok, to clarify for you the 9EIX9 superseded or replaced the 9EVX9s (that is why you can't find them)
Old Jan 28, 2012 | 10:28 AM
aja's Avatar
aja
Perfect, thank you. I came out to start my hawk this morning and she will kick on at full choke but is very rough and dies with any throttle. I'm hoping its just plugs, I pulled the front wire and started it with the same behaviors so I'm pretty sure it is.
Old Jan 28, 2012 | 02:02 PM
aja's Avatar
aja
I hope its only plug. It ran fine last night. Pulling the front wire made it a little worse but not much, which makes me think the plug is worn. The bike has 19k miles, I've had it for about 1k so I doubt they've ever been changed
Old Jan 28, 2012 | 02:06 PM
Well a new set of plugs never hurts....
With that, the way to check these plugs is, pull it out..... kind of obvious.....lol
Take a round wire plug gap gauge of the proper size ( I would have to check the manual but it is in there) and check the plug gap.
If it has opened up, then the plug is worn out and needs to be replaced, no matter how good or bad it looks.
Old Jan 28, 2012 | 03:24 PM
aja's Avatar
aja
They were toast. New plugs didn't help. Carbs come off tomorrow, we will see what happens.
Old Jan 28, 2012 | 04:48 PM
Also that time of the year for water contamination of the fuel.
Old Jan 28, 2012 | 05:22 PM
On the other hand, my wife's SV calls for standard plugs (4 of them), and I replace them at about 10k miles. Overall, cost of 4 plugs for her bike is slightly more than what I pay for 2 iridium NGKs.
Um, my wife's sv took 2 plugs. One for each of 2 cylinders. Did they switch to a dual plug set up later in production?
Old Jan 30, 2012 | 01:52 AM
Stephan's Avatar
Denso IX27B works fine, for me better than OEM NGK - smoother at low rpms. Costs around 10 dollars per each.
Old Jan 30, 2012 | 02:56 AM
NKG DPR9EIX-9 I pay $6.86 each from my source
Old Jan 30, 2012 | 07:26 AM
aja's Avatar
aja
I couldn't get them anywhere and they would take too long to be shipped so the parts guy at the local cycle store gave me some that he said he was 99.9% sure would work. They are ngk but I forget what number. They seem to be ok. A little rough at idle and low rpms but they will do until the EIXs come in.
Old Feb 29, 2012 | 07:35 PM
Kelevra's Avatar
4 for $32 shipped. Ebay.
Old Mar 1, 2012 | 01:12 AM
tomzxt's Avatar
Light Cycle Expert
$6.09 each for me at Advanced Auto. Takes 2 hours to be delivered from the warehouse.
Old Mar 1, 2012 | 08:19 AM
Kelevra's Avatar
You win. :-)
99Hawkboy
May 31, 2018 08:02 AM
hondavtr1000sp2
Nov 17, 2014 09:07 PM
gpz4jp
Jan 25, 2007 04:26 PM
rageohio
Sep 30, 2006 02:57 AM
mamisano
Apr 3, 2005 12:41 AM
