SuperHawk Shift Clunk
Old Mar 17, 2010 | 12:38 PM
Aramis's Avatar
Aramis is on a distinguished road
SuperHawkers,
When I'm riding my SH and if I come to a light and put the bike in neutral then shift to 1st when the light changes the SH makes a loud clunking noise and the bike jumps a little bit.
Is this a normal quirk with the SuperHawk's clutch? I've read some other posts and I get the impression it is but I want to make sure I'm not having a more serious clutch issue.
Old Mar 17, 2010 | 01:01 PM
That's normal, so long as it isn't trying to actually go and is just a bit of a jump.
Edit: it still might be a good idea to replace the clutch fluid though.
Old Mar 17, 2010 | 01:56 PM
slabm7's Avatar
Mine does this as well, I did some research and it seems to be a normal thing.
Old Mar 17, 2010 | 03:49 PM
superbikemike's Avatar
superbikemike
Mine makes the clunk but it doesn't move.
Old Mar 17, 2010 | 04:48 PM
Mikos_24's Avatar
Mikos_24 is on a distinguished road
I had the same. Check your idle speed. I had 1300 rpm and after reducing it to 1100 rpm bike stopped jumping
Old Mar 17, 2010 | 04:58 PM
Actually it's normal for just about all bikes.
It has to do with the way the bike trans uses shift dogs and even with the clutch pulled in, the input shaft is still spinning (like if you put the bike on a rear stand and start it, the rear wheel starts spinning even in neutral)
So when the spinning shaft engages the stationary shaft you get the clunk.
Like the previous poster stated, keep the idle speed in spec and it should minimize the noise and eliminate the jumping.
Old Mar 17, 2010 | 05:22 PM
CANADAVTR's Avatar
CANADAVTR is on a distinguished road
Hold the clutch in for a couple of seconds before hitting the gearshifter...that might help. But yes, a clunk is normal.
nova_scotian_996
Jan 1, 2007 03:37 PM
MXC
Jun 18, 2006 05:16 PM
L8RGYZ
Jun 9, 2006 04:35 AM
redline76
Jan 21, 2006 12:53 PM
Rufion
Jan 13, 2006 07:15 AM
