Stupidity causes MCCT failure, potential damage?
Old Feb 8, 2013 | 09:00 PM
mike21091's Avatar
mike21091 is on a distinguished road
I may be the first to have a manual came chain tensioner fail. I must not of torqued the front cct mounting bolts down properly since it let loose at a stop light.
Now what are the chances of the valves and head being OK since it died at idle and not at speed or have I munched the head either way.
Thanks in advance.
Old Feb 8, 2013 | 09:29 PM
HRCA#1's Avatar
Well munching the head is a bit extreme. Most you may have done is kissed the valves on the piston, especially if at idle. All that means is it probably didn't take out the guides but still may/did bend the valves.
What failed on the manual cct? Haven't heard of a failure.
Old Feb 8, 2013 | 09:38 PM
Thanks in advance.
You are not the first, did you hear any knocking noise before it died??
Old Feb 8, 2013 | 10:57 PM
98VTRrider's Avatar
you are not the first, don't feel bad...I doubt I was the first either....I forgot the locktite on the MCCT lock nut when I did a valve adjustment...then I ignored the obvious tapping I heard when I was riding on the highway, it let loose coming off an exit ramp when I tried to idle
Old Feb 9, 2013 | 06:36 AM
CCT didn't fail directly it sounds like the mounting bolts loosened up
Old Feb 9, 2013 | 10:52 AM
JakeT's Avatar
JakeT is on a distinguished road
Thanks in advance.
There is someone selling some heads in classifieds. Heads aren't too costly for our bikes. That would be worse case scenario. Well not worse case but from what it sounds like Doubt you smashed the piston too hard.
Old Feb 9, 2013 | 06:01 PM
mike21091's Avatar
Yeah the mounting bolts backed out since I didn't loctite them and didn't torque them properly. I had stopped at a light and the idle slowed down to about 600rpm and then it started knocking and died.
Old Feb 9, 2013 | 10:02 PM
mike21091's Avatar
Just got it retimed and back together and it taps and needs full choke and some throttle just to idle. Shut it off a couple seconds later, guess I bent the valves.
Old Feb 10, 2013 | 07:48 AM
Sounds like the valves.... the bike was running on one cylinder, one cylinder cannot keep compression, there for the chock you needed just to keep it idle.
Old Feb 11, 2013 | 01:56 PM
GTS's Avatar
GTS
Seasoned tech
Man sorry to hear that. Same thing happened to mine 3 days after I bought it. But on mine it was the a-hole that sold me the bike that didn't get them tight.
Should have checked the valve clearance when you timed it. If it had a lot of clearance that would have showed you if the valves were bent or not.
I hope it's not to bad!
Old Feb 19, 2013 | 03:33 PM
mike21091's Avatar
FYI updates are going to be in my ThriftyHawk log here. https://www.superhawkforum.com/forum...led-log-29760/
quillinsmat
Jun 8, 2014 09:41 AM
pwshadow
Jan 2, 2011 02:31 AM
trevorh1
Aug 8, 2009 08:55 PM
Dano
Feb 20, 2009 02:50 PM
bluesman
Nov 8, 2004 06:26 AM
