Stupidity causes MCCT failure, potential damage?
I may be the first to have a manual came chain tensioner fail. I must not of torqued the front cct mounting bolts down properly since it let loose at a stop light.
Now what are the chances of the valves and head being OK since it died at idle and not at speed or have I munched the head either way. Thanks in advance. |
Well munching the head is a bit extreme. Most you may have done is kissed the valves on the piston, especially if at idle. All that means is it probably didn't take out the guides but still may/did bend the valves.
What failed on the manual cct? Haven't heard of a failure. |
Originally Posted by mike21091
(Post 348991)
you are not the first, don't feel bad...I doubt I was the first either....I forgot the locktite on the MCCT lock nut when I did a valve adjustment...then I ignored the obvious tapping I heard when I was riding on the highway, it let loose coming off an exit ramp when I tried to idle
Originally Posted by HRCA#1
(Post 348992)
(Post 348991)
Yeah the mounting bolts backed out since I didn't loctite them and didn't torque them properly. I had stopped at a light and the idle slowed down to about 600rpm and then it started knocking and died.
Just got it retimed and back together and it taps and needs full choke and some throttle just to idle. Shut it off a couple seconds later, guess I bent the valves.
(Post 349031)
Man sorry to hear that. Same thing happened to mine 3 days after I bought it. But on mine it was the a-hole that sold me the bike that didn't get them tight.
Should have checked the valve clearance when you timed it. If it had a lot of clearance that would have showed you if the valves were bent or not. I hope it's not to bad! |
FYI updates are going to be in my ThriftyHawk log here. https://www.superhawkforum.com/forum...led-log-29760/
