stumble at 7k rpm
Old May 8, 2011 | 10:10 AM
smk2mch87's Avatar
smk2mch87 is on a distinguished road
stumble at 7k rpm
ok seein how i cant get an answer on the old thread, thought id start a new 1... just did my ccts and my timing was way off, im 99% sure the timing is dead on now but my bike wont go past 7-7500 rpm. any ideas on that? did a bafflectomy a few days b4 the ccts went out but i would still redline no prob
Old May 8, 2011 | 10:54 AM
cliby's Avatar
Describe more. What do you mean? Does it just bog and stumble at 7? Need the details.
Old May 8, 2011 | 12:03 PM
Pantaloonie's Avatar
Pantaloonie is on a distinguished road
Your timing is out by 180 degrees.
Old May 8, 2011 | 12:12 PM
nykuryu's Avatar
nykuryu is on a distinguished road
why do you think your timing is correct now? you made sure you were at the FT for the fronts and RT for the rears right? front TDC lobes are up and out, TDC rears are up and in.
Old May 8, 2011 | 07:02 PM
smk2mch87's Avatar
oh snap both front and rear are up and in... damnit lol. it runs strong til 7 tho then just kinda like a bog/ rev limiter its weird
Old May 9, 2011 | 12:34 PM
smk2mch87's Avatar
think itll be alright 2 ride as long as i go easy? im waitin on a valve cover gasket to get here n itll rain the rest of the week
Old May 14, 2011 | 02:21 PM
smk2mch87's Avatar
ok well i tore it back down and my timing is right... any other ideas why it would stop at 7k?
Old May 14, 2011 | 02:50 PM
Are you getting spark on both cylinders? Even if you are, a coil that is going out "could " cause the problem you describe.
Old May 14, 2011 | 02:57 PM
I used to run into that kind of problem with carburetor equipped cars from time to time. Sometimes they would just die if you floored it at a certain speed, then you'd let off the gas and it would run fine as long as you didn't go over that certain speed. 9 out of 10 times it was a clogged fuel filter. It even happened to my '70 Chevy Nova SS while it was still under warranty. The dealer did all kinds of stuff trying to find the problem, then they dropped the tank and found the filter sock was clogged.
Check your fuel filter for contamination. Unless you've added inline filters, the only filter is a "sock" type attached to the fuel outlet/petcock assembly at the bottom of the tank. It might be coated with gunk.
If that's not it, try cleaning the carbs. Could be a restricted jet. Also check the carb diaphragms.
Old May 15, 2011 | 01:45 AM
PUSHrod's Avatar
And don't forget to check that fuel tank vent hose and tube. A clog there, or a partial kink or constriction, would cause a drop in fuel flow just as the motor ramps up the demand.
Old May 15, 2011 | 01:48 PM
smk2mch87's Avatar
k i will check all these... get back with ya soon
Old May 16, 2011 | 02:33 AM
acks's Avatar
acks is on a distinguished road
Please update when you have found the problem. I seem to have the same issue Iv just had my motor replaced.....and now this has started. ( However, mine is the Honda VTR Firestorm )
She has all the pull off power in the world, but around 5.5K RPM, it feels like she is running out of fuel, then comes back, and does it again. It limits at different revs per gear.....I suspect its carbs and settings tho.
Old May 16, 2011 | 05:24 AM
RWhisen's Avatar
Former Superchicken Owner
Check the easy stuff first. Ensure the hoses to your tank are correct, petcock is functional and carbs are clean. Good spark at the plugs? How old are the coils?
Old May 16, 2011 | 11:54 AM
The other cause for this kind of problem is the side stand switch. Check to see if it is loose or dirty. You can also by pass it to test to see if it is the problem but I would recommend either repairing or replacing it as it is good to have one on your street bike.
jonymo
Aug 2, 2010 06:53 AM
oahu hawk
Mar 2, 2009 07:33 PM
Red_Liner740
Jul 20, 2008 12:51 AM
driven
Sep 16, 2007 12:15 PM
Utah996
Apr 29, 2006 09:27 AM
