Low speed turnin stumble...
Old Feb 24, 2009 | 07:28 PM
oahu hawk's Avatar
geezer
Just recently the engine on my Hawk has been exhibiting a minor stumble when leaning to make a sharp low speed turn, such as into a driveway or when making a tight 180. It's only a momentary hiccup that happens at low RPMs and goes away with throttle application...this occurs when turning in either direction.
Anyone experience this and/or know what the fix is?...don't want the engine dying on me in this situation...
Old Feb 25, 2009 | 10:50 AM
oahu hawk's Avatar
geezer
bump...
Old Feb 25, 2009 | 11:10 AM
PUSHrod's Avatar
Mine did it too, back in the dark ages, symptom went away after extensive modifications including high compression pistons and sport cams.
You might want to check your idle adjustment or carb balance. Huge throats on those things, when the engine speed drops and the velocity of the air goes down, the venturi effect weakens. Idle too low and/or balance being just a little out will cause what you describe.
Good luck out there.
Old Feb 25, 2009 | 12:37 PM
oahu hawk's Avatar
geezer
Carbs were balanced not too long ago, maybe need to check them again...idle speed is 1200 rpm...
Tks for your reply...
Old Feb 25, 2009 | 01:26 PM
cameron's Avatar
mycarbs where stumbling at low rpms when i first got the bike but after a jet kit was installed the mechanic said the carbs were dirty and that was most likley the cause? after the jet kit a cleaning and a synch no more stumbling.
Old Feb 26, 2009 | 02:01 PM
PUSHrod's Avatar
I wonder if you don't have some water in the bottom of your float bowls...slow speed, steep angle turns would cause it to enter to low speed jet. Perhaps.
Old Feb 26, 2009 | 03:17 PM
j shizzy wizzy's Avatar
mildly retarded
next fill up put some seafoam in there and burn through it. I've heard it works wonders. it was discussed recently on here too.
Old Feb 26, 2009 | 04:48 PM
kevink2's Avatar
kevink2 is on a distinguished road
Check fuel filter in tank?
Old Feb 27, 2009 | 10:02 PM
nath981's Avatar
I want to jump in here since you mentioned tank filter. Is there a certain procedure for removing the petcock/filter? I have sputtering, backfiring, stalling since I took the air cleaner off to find a couple bolts i dropped. I tried to remove the petcock and couldn't get the filter out. Didn't want to force it/
What's the trick?
thanks, Nathan
Old Feb 27, 2009 | 10:15 PM
HawkFanatic's Avatar
HawkFanatic is on a distinguished road
stretched/distorted throttle cable?
At a dead stop turn the handlebars all the way left and right and see if that affects idle.
I had this problem on my old VFR
Old Feb 27, 2009 | 11:05 PM
The fuel level in the float bowl may be creeping up when the bike is at an angle. Check the float needles for wear.
Any other symptoms?
Old Feb 27, 2009 | 11:21 PM
oahu hawk's Avatar
geezer
Any other symptoms?
no other symptoms...bike has just over 14K miles and otherwise runs great...
Old Mar 2, 2009 | 04:28 PM
kevink2's Avatar
What's the trick?
thanks, Nathan
I too had the same problem. I didn't want to risk tearing the mesh, so I pulled it out as much as possible and cleaned the bottom of the filter as best I could. I'm told I just need to man up and remove it. Anyway, it seemed to get rid of a stalling problem I was having, turning right, up a steep driveway.
Old Mar 2, 2009 | 07:33 PM
nath981's Avatar
thanks kevin, I didn't want to destroy it without justification, but mine was totally clean. I wanted to get it loose and take the petcock apart to see how it worked. Anyway, It must be okay since i did the TPS, the air mixture and shiimed the needles and it runs well from idle to max rpms.
thanks, nathan
chp_hates_me
Aug 27, 2011 03:59 PM
jonymo
Aug 2, 2010 06:53 AM
seb421
Jun 29, 2009 10:32 AM
luv2insanity
Aug 31, 2008 08:05 AM
Red_Liner740
Jul 20, 2008 12:51 AM
