still need HELP
still need HELP
hey guys its been a while but i got some work done had the carbs cleaned went in and checked the timeing all that stuff is good but still have the same problem around 6 to 7000 rpm if i get on the gas hevay it sputers falls on its face but if i am easy on the gas it is ok so someone pleas pleas pleas help help help
Very likely. You can't trust the techs now-a-days, even at the dealer. Learn how to do it yourself, if you have basic mechanical skills.
I've found they can't even torque an axle nut correctly, so I'm buying a front stand before I need tires again.
