still need HELP
Old Apr 19, 2011 | 07:04 PM
vtr1000f/99's Avatar
vtr1000f/99 is on a distinguished road
still need HELP
hey guys its been a while but i got some work done had the carbs cleaned went in and checked the timeing all that stuff is good but still have the same problem around 6 to 7000 rpm if i get on the gas hevay it sputers falls on its face but if i am easy on the gas it is ok so someone pleas pleas pleas help help help
Old Apr 19, 2011 | 07:09 PM
nykuryu's Avatar
nykuryu is on a distinguished road
mods? im guessing lean since that around where the transition is in the jets depending on vacuum. anyone got that transition graph ready?
Old Apr 19, 2011 | 09:33 PM
Are you running a stock air filter?
Old Apr 19, 2011 | 10:03 PM
PVLIR....... the "had the carbs cleaned" is the clue......
Old Apr 19, 2011 | 10:04 PM
You go from the pilots to the mains between 3-4K RPM
Old Apr 19, 2011 | 10:30 PM
nykuryu's Avatar
i thought you transition based on your throttle opening, not your RPM. if your getting hesitation at WOT i would suspect too small mains.
Old Apr 19, 2011 | 10:58 PM
Very likely. You can't trust the techs now-a-days, even at the dealer. Learn how to do it yourself, if you have basic mechanical skills.
I've found they can't even torque an axle nut correctly, so I'm buying a front stand before I need tires again.
superhawk22
May 6, 2010 12:08 PM
cagedruss
Jun 20, 2008 06:19 PM
Darrell400ex
Nov 23, 2007 06:35 PM
redman
Nov 11, 2007 01:34 PM
L8RGYZ
Sep 3, 2006 06:21 AM
