squeaking noise on accel
Old Nov 13, 2008 | 05:36 PM
Death Cattle's Avatar
the title pretty much explains it. its only on accel, never on decel. its hard to tell if it goes away at a certain rpm due to noise increase. its not a high pitched whining, just more of a squeaking. any ideas would be appreciated. thanks.
Old Nov 13, 2008 | 06:21 PM
jbaxx's Avatar
Honducati
Where does the noise sound like it's coming from? Front? Rear? Exhaust? Engine? Suspension?
Old Nov 13, 2008 | 06:42 PM
oops, sorry. it definitely sounds like its coming from the front end. its hard to tell whether or not its coming from the engine.
Old Nov 13, 2008 | 07:02 PM
jbaxx's Avatar
Honducati
Well, you could try jouncing (a technical term for bouncing) the front suspension with the bike not running. Also check for an exhaust leak. Small leaks at high pressure (on accel) could sound squeaky. Look for scorch marks around your exhaust fittings and joints.
Old Nov 13, 2008 | 07:12 PM
cool, ill try those things. thanks. still open to any other suggestions
Old Nov 13, 2008 | 07:43 PM
Little_Horse's Avatar
2nd mouse gets the cheese
look for things that might rub the suspension lifts a little, that is if the squeak happens once, and not the whole time when acellerating. Just trying to help
Old Nov 13, 2008 | 08:43 PM
Check to see if something got sucked into your air intake/filter.
Old Nov 14, 2008 | 04:30 AM
happytrack44's Avatar
WERA #44
Sounds like a scared mouse to me.
Old Nov 14, 2008 | 09:02 AM
dsevans's Avatar
dsevans is on a distinguished road
sqeek
I have the same thing. I have sort of written it off, because it does not seem to come from the engine.
I would like to know if anyone narrows it down.
Thanks you.
Darren
Old Nov 14, 2008 | 10:14 AM
finepooch's Avatar
i have some sort of squeak too. it happens on accel and cruising, not deccel. it bothers me too. i keep thinking cam chain or something, but i really haven't got an idea.
what about the signature "honda whirl/whistle"? that is annoying too.
finepooch's Avatar
oh, is you chain properly lubed?
Old Nov 14, 2008 | 11:15 AM
mfast1's Avatar
mfast1 is on a distinguished road
I too have this same noise , i think its the chain but damn if u can tell , i lubed my chain pretty good and seemed to go away then came back , only hear it on take off in 1st gear .
Old Nov 14, 2008 | 01:53 PM
dantropolis's Avatar
dantropolis is on a distinguished road
Hard acceleration may be unloading the forks enough to increase tension on all your cables which may cause them to rub / vibrate on any guides or body parts they don't normally touch. I had this happen on a BMW but it presented like a pebble rattling around in the headlight.
Maybe experiment with wrapping the front brake line in electrical tape wherever it goes through a guide or near or tweeking the guide one direction or the other?
Old Nov 14, 2008 | 05:01 PM
finepooch's Avatar
i think my squeak was the chain. i neglected it, loud squeaks. lubed it up and squeaks went away. i'm getting a new chain so it doesn't matter much. more worrysome is that i'm concerned about losing my sanity.
Old Nov 22, 2008 | 03:11 AM
it was definitely the chain. i lubed it up today and no squeaks at all. just so you all know.
ericrosendall
Nov 25, 2009 07:30 AM
The Hawk Guy
Sep 9, 2007 12:26 AM
midijunky
May 2, 2007 05:15 PM
SuperHawkins
Mar 29, 2007 06:21 AM
05xman
Nov 2, 2006 10:27 PM
