Sputtering and cuttin out?
Old May 2, 2009 | 11:26 AM
hollywood13185's Avatar
hollywood13185 is on a distinguished road
Hey guys my VTR 1000 is sputterin and cuttin out, I dont know anything about these. Adjusting the idle doesnt help. I noticed also it looks like to vaccum ports that come off the base of the carburator in a Y are open, theres no lines goin to em and there not plugged. Could that be it? When you rev it, it hesitates and sputters and cuts out, also at a steady rpm. Any ideas. Thanks again guys this website has been a ton of help.
Old May 2, 2009 | 01:44 PM
PUSHrod's Avatar
Not much information to go on, but working from free to cheap, assuming that you have tools and the haynes manual...
old or bad or contaminated gas
water in the float bowls
plugged gas tank vent
cracked vacuum line to petcock
leaking or loose carb boots
corrosion on the connectors for the ignition system
free tune up done by a new friend
The official Honda shop manual has an excellent diagnostic chart, but only you know the recent history, when the symptom occurred, and your set up. Need more information to narrow the suggestions for remediation.
Old May 4, 2009 | 05:04 AM
nothing's Avatar
ride it out
i had a vac line that was just open couldnt figure out where it went so i just plugged it and now it runs just fine.
Old May 4, 2009 | 05:56 AM
Riff's Avatar
Ottawa, Ont.
Riff is on a distinguished road
I'd guess it's either the vacuum port/hose or the TPS. The front vacuum port is plugged at the venturi, the rear has the hose running to the petcock. Make sure this hose is attached to the vacuum port on the petcock.
A poorly adjusted TPS will also manifest this way. See your Svc Manual.
Old May 9, 2009 | 03:25 PM
Thanks for the tips guys I havnt had time to work on it but will today. I dont have the manual. My brother bought the bike a year and a half ago, and when he joined the army he gave it to me. It has sat for a little over a year so Im hopin its just old gas. Thanks again, Josh
Old May 9, 2009 | 03:55 PM
Service manual is available here: https://www.superhawkforum.com/forum...ad.php?t=11365
Old May 9, 2009 | 04:32 PM
Thanks for that link, I should also mention that it idles fine it just acts up when I rev it or give it constant throttle.
Old May 9, 2009 | 05:47 PM
finepooch's Avatar
hopefully just old gas because that comes with the easiest and cheapest fix.
Old May 10, 2009 | 01:43 PM
PUSHrod's Avatar
Sat for a year? Probably you are looking at a good carb cleaning. Were they drained first? Hope so.
Old May 14, 2009 | 10:22 AM
I dont think they were drained, my brother took off too the army and just left it in my garage, and I dont know much about bikes. It has the same gas in it since he left. I dont think he did anything to it. would running a bottle of carb cleaner through it help?
Old May 14, 2009 | 12:39 PM
Stevebis1's Avatar
Carb cleaner could help. My personal favorite is Seafoam as this will absorb any water too. Drain/syphon out the tank, fill with fresh gas and 1/3 can seafoam. If it improves, add another third next fill up.
Since it has been sitting and you don't know how your brother left it, change the oil & filter (easy), replace the plugs (bit more involved, read through the manual)
Old May 14, 2009 | 02:03 PM
Ya i changed the oil already. I just had the bike down to the carbs checkin things out. I took the petcock apart but couldnt get it all the way out. Seems its getting gas through it tho. When I first put the tank back on and fired it up it didnt sputter or hesitate. Reved real smooth. Then after i put it all back together (seat, tank and so on) It started sputterin and crap again. Where is the gas tank vent located, could that be causing the problem?
Old May 14, 2009 | 02:16 PM
PVLIR? The bottom nipple on the petcock should not be connected to anything, the one on the back that points to the right is the vacuum line.
Old May 14, 2009 | 02:27 PM
Ya I had that hooked up right. small line from the back of the petcock and then the two larger lines on the sides? right?
Old May 14, 2009 | 04:18 PM
Yup. Make sure it's the small line with the wire clamp. The other small line goes to the overflow or tank vent.
b1m3x8
Apr 21, 2012 09:29 AM
t-dogg
Dec 27, 2011 04:33 PM
AngryOlaf
Nov 12, 2009 09:29 PM
mn.cadena
Aug 24, 2008 05:26 PM
matix
Oct 6, 2005 06:57 PM
