sputtering around 4-5k rpm, any sugestions?
Old Sep 17, 2005 | 07:43 PM
caffeineracer's Avatar
caffeineracer
Did it happen soon after refueling?
If you over fill them, the tank vent can fill with fuel and cause that.
Fix is open the fuel tank cap and break the tank vacuum.
~Jeffers
Old Sep 18, 2005 | 12:55 AM
swordfish's Avatar
Re: sputtering around 4-5k rpm, any sugestions?
either that or you are out of gas. remember they are gashogs. but even after the engine dies, you can get it going and baby it on fumes for about a mile. but its really bad for the fuel pump.
Old Sep 18, 2005 | 07:08 AM
superbling's Avatar
No fuel pump on a superhawk, gravity feed only; might be why they hydro-lock so easily.
If you fill the tank up too much which almost everyone does to get a liiiiiitle more range, the vent tube is blocked/stopped causing the petcock to pull a vacuum on the tank which eventually stops fuel flow. Engine sputters for a bit and then dies from lack of fuel to the carbs. Open tank for a couple of seconds/close, restart, and next time don't fill it up so high! :wink:
Old Oct 5, 2005 | 11:25 PM
cb21983's Avatar
cb21983
Is it a consistent sputter at 4-5k? Was it a one time only deal? If your bike keeps dying at a light remember that your idle should be set at 1200RPM.
Old Oct 6, 2005 | 07:33 AM
VTRFISH's Avatar
VTRFISH
A pinched fuel tank line had me scratching my head for a bit. Acted fuel starved....well it was .....caused fuel lock.
Mike
Old Oct 6, 2005 | 06:57 PM
VTR69's Avatar
VTR69
I wonder if the previous owner(s) ever shimmed the needles up in your carbs. They run rough as hell below 3,000 rpm till you rich up the mixture. At least mine did. Hope this helps.
RequestTheOverhead
Jun 26, 2012 11:05 AM
hollywood13185
May 14, 2009 04:18 PM
mn.cadena
Aug 24, 2008 05:26 PM
SH1000MA
Apr 24, 2007 03:56 AM
Randman
Sep 4, 2006 10:23 AM
