Spiegler brake line install problem
Old Jun 16, 2007 | 12:28 PM
cscrawford's Avatar
cscrawford is on a distinguished road
Question Spiegler brake line install problem
I ordered Spiegler Stainless brake lines for my 03 SH. My options were:
VTR 1000 F 97 - only alt. 2-line Front 2 S-HN0131 $109.95
Or
VTR 1000 F 97 - orig. w/ manifold Front 3 S-HN0132 $174.95
Of course I bought the less expensive 2-line set. They do NOT look correct. I basically received two lines with the banjo "O" at each end. The BIKE shows the "O" at the end that bolts to the caliper, but the section where the lines meet (above the tire near the steering head) appear to be a monoblock/single unit.
Did I order the wrong set?
Old Jun 16, 2007 | 01:27 PM
It should have a longer "bolt" and you put one banjo on top of the other.
Old Jun 16, 2007 | 01:37 PM
Thumper's Avatar
Or
Both line should completely replace the stock line from the master cylinder to the calipers. Otherwords, each new line runs from a caliper to the master cylinder and a longer banjo bolt (provided in the kit) bolts both lines to the master cylinder at one time.
Old Jun 16, 2007 | 02:19 PM
And the lines are within millemeters of being switched from one side to the other. I did this update recently and had to do it twice because I did not think they were that close.
I am constantly reminded that this not a '67 Corvette but a Swiss watch - that also happens to go a hundred miles per hour in a very short amount of time.
It's a relic but it's the fastest f+ching relic on the planet!
Old Jun 16, 2007 | 03:17 PM
cscrawford's Avatar
Wow. Seems kind of like a slight Jerry Rig. I guess I'm just extra paranoid on front breaks. I only use my rear brakes on occasion just to make sure I don't forget how it works.
I too noticed one line was slightly longer than the other. Any memory as to which side (sitting on the bike) is the longer of the two?
Great advice! Thanks!
Old Jun 16, 2007 | 03:28 PM
The slightly longer line goes to the left caliper. Forget about the stock routing through the frame-mounted loops and go straight for the device - on both ends - both sides.
Iz cool!
Old Jun 16, 2007 | 06:41 PM
cscrawford's Avatar
Heading to the garage for brakeline surgery now...
Old Jun 16, 2007 | 06:47 PM
I cut the rubber grommets off the stock lines and use them in the brackets on the front fender. They are a little loose around an aftermarket line but they are retained nonetheless. The grommets are glued on. I just cut lengthwise with a razor blade and slowly remove it from the stock line.
Old Jun 16, 2007 | 08:29 PM
Thumper's Avatar
You can actually super glue the rubber back together where you cut it after wrapping around the new lines. Do not glue to the new lines. You can also use extra small black tie wraps or zip ties around the new line just above and below the rubber bushing to keep everything in place.
Old Jun 16, 2007 | 08:33 PM
Thumper's Avatar
Iz cool!
+1 on the longer line to the left caliper, however i did use the stock frame mounting loops with no problem on mine.
You should notice a big difference in brake feel
If you have difficulty getting all of the air out after bleeding the new lines, you might have to cover the painted surfices up for protection and bleed the brake lines at the upper banjo bolt. Air can get trapped there as it is the highest point in the whole system other than the resevoir.
Old Jun 16, 2007 | 09:59 PM
cscrawford's Avatar
Well, I got it done. WAY firmer at the lever. The little plastic holding block intended to hold the line in a vice so you can twist the end is a POS. I tightened it, but the line still slipped...tried to tighten more and the thing started to mangle. It made me cringe and I was very, very careful...but I used curved pliers to twist. Worked, and didn't seem to crush the aluminum at all, but was definitely the high blood pressure moment of the job, that and spilling the brake fluid bottle.
I just put the aluminum end in a soft wood vice just to hold it, and turned the fitting with the (errr...pliers).
Where the two line ends are held on by the longer aluminum bolt...I used an aluminum washer on each end, but had two left over. I put one washer BETWEEN the two ends (banjos?). I put in two but it made the spacing look iffy, so went back to one. I snugged everything and pulled hard on the lever, checked for leaks and all looks good. I somehow locked myself out of my tool box...doesn't have a key lock. I'll have to crack that safe in the morning so I can use my torque wrenche for the aluminum bolt.
I really appreciate the advice. Couldn't have started without the help! I'll ride it and see what happens in slow turns, fork compression etc. then tackle keeping the lines in their proper place. Definitely made a huge difference.
Old Jun 17, 2007 | 06:34 PM
The aluminum banjo is very fragile. Don't overtorque it. I prefer steel for this application. YMMV.
Old Jun 17, 2007 | 06:42 PM
cscrawford's Avatar
Yep. I'm glad I had the wood-jawed vice. Brake lines aren't somewhere want to cut much from, even weight. I was a bicycle mechanic in college and learned the hard way...the right way to work with aluminum.
Thanks again.
KCCO
May 28, 2013 07:49 PM
KC-10ENG
May 19, 2011 01:09 PM
Ludicrous_Speed
Jun 27, 2010 05:32 PM
ff
Apr 1, 2010 09:39 AM
VTR69
Feb 24, 2006 07:21 PM
