Russell SS Brake Line Install Troub
Old Jun 27, 2010 | 11:55 AM
Ludicrous_Speed's Avatar
Ludicrous_Speed is on a distinguished road
Here is what I ordered from DennisKirk.com http://www.denniskirk.com/jsp/produc...Id=&mmyId=2028
On the box it says 98 vtr1000f Frt brk Ln Part No: 09362
Heres the Bike. There is a hardline junction where the lines split off to the calipers. How does the Russell kit replace that? Im a little stumped here. Thanks
Old Jun 27, 2010 | 12:12 PM
cliby's Avatar
you lose all of that junction box (not a bad thing) and you use the double banjo bolt at the MC and run two separate lines - one to each caliper. The longer goes to the left caliper. The only issue is bleeding. once you get it all hooked up you will have to bleed it at the banjo bolt early to remove the air. very simple to do but will be necessary.
Old Jun 27, 2010 | 01:01 PM
THANKS. Figured it out finally lol. The banjo bolt is where it attaches to the reservoir? Is this like a car where I top off the reservoir then undo the bleed screws on the calipers?
Old Jun 27, 2010 | 02:50 PM
The banjo bolts is where it attaches to the master cylinder and the calipers. Yes you do bleed from the screws on the calipers but you should also pump the system up and slightly loosen the banjo bolt at the master to make sure there is no air bubble trapped at the top of the system.
Old Jun 27, 2010 | 05:32 PM
Cool thanks for help, the job is complete.
F1 Fan in Nascar Land
Apr 19, 2015 07:16 PM
cscrawford
Jun 17, 2007 06:42 PM
Verne
Feb 6, 2006 06:12 PM
CNI Dawg
Nov 6, 2005 06:59 PM
