speedo inop, and lean pop on decel
If any of you can help me I would be very greatful. This is my 1st superhawk, I am a M/C technician, so I'm not helpless. My bike has seen some hard miles, it pops and backfires on decel even with choke applied and part of the air box intake blocked off. So I think its in the air valve on the carb, and not the jetting but I'm not sure. It has a full jardine exh system, and I've been through the carbs, but could use a schematic if someone has one. Also my speedo is inop and w/o a manual idk where to start, odometer says ------ constantly. Any help would be great.
Forum noob
SuperCleat
Forum noob
SuperCleat
Listen to Residentg. the popping is most likely coming from your PAIR. This is an emissions system that pulses air into the exhaust to burn off excess fuel. when you decel hard it dumps raw fuel into the exhaust which is then ignited by the pulse of air and creates a loud pop which is usually accompanied by some flames. Mine popped really loud when i had holes drilled in the muffler but when i removed the baffles completely the sound mellowed out quite a bit.
ClevelandSuperhawkRumble
Mar 13, 2005 03:09 PM
