Slave cylinder help
Old Aug 7, 2012 | 09:33 PM
bjaykay's Avatar
bjaykay is on a distinguished road
Slave cylinder help
I recently removed the slave cylinder on my 98' Hawk to get to the front sprocket but after replacing it I realized that when I apply the clutch the bike wont be in neutral and I cant switch gears. I'm not sure what I messed up and I don't want to be randomly messing with it to try to fix it so if anyone has a solution I'd appreciate the help thanks
Old Aug 7, 2012 | 10:22 PM
Release the slave bleeder located on top of the slave from fluid pressure! That should fix it. You may need to bleed the system as well
Old Aug 8, 2012 | 04:46 AM
Bleed the clutch, all should be fine.
Good opportunity to get that old fluid out of the system anyway.
Old Aug 8, 2012 | 06:05 AM
+1, you should do it every 3 years at the minimum anyway, these systems get sucked in about 3% moisture a year depending on the environment you live in and the system conditions, thus your hydraulic systems also need regular maintenance to insure that it operates with no failure.
Old Aug 9, 2012 | 08:27 PM
bjaykay's Avatar
Yea I drained and replaced the fluid and everything is working fine thanks for the help
NewGuy
May 12, 2014 11:32 AM
98VTRrider
Jun 2, 2011 05:53 AM
Streaky
Apr 19, 2010 08:24 PM
trinc
Mar 18, 2009 10:47 PM
nineighthawk
Apr 26, 2007 10:04 PM
