Slave cylinder help
I recently removed the slave cylinder on my 98' Hawk to get to the front sprocket but after replacing it I realized that when I apply the clutch the bike wont be in neutral and I cant switch gears. I'm not sure what I messed up and I don't want to be randomly messing with it to try to fix it so if anyone has a solution I'd appreciate the help thanks
Originally Posted by bjaykay
(Post 339547)
Bleed the clutch, all should be fine.
Good opportunity to get that old fluid out of the system anyway. |
(Post 339553)
Yea I drained and replaced the fluid and everything is working fine thanks for the help
