she just quit
Old Apr 29, 2011 | 08:39 AM
dutchdude's Avatar
moto gp wannabe
dutchdude is on a distinguished road
Question she just quit
riding the hawk to work this morning and she just quits- no noise nothing mechanical - all electronics just went away- I did a quick roadside check of fuses,battery terminals and such. Couldnt find the problem. granted I have to look a little deeper when i get home tonight but does this sound familiar to anyone?
Old Apr 29, 2011 | 09:36 AM
Wicky's Avatar
Check R/R, double check battery connections are tightened up, also main 30amp fuse - If not then could be that the bike's brain box died (IGN Module / CONVERTER UNIT)
http://www.ronayers.com/Fiche/TypeID...p/WIRE_HARNESS
Old Apr 29, 2011 | 09:50 AM
SPRHK's Avatar
my e-penis is huge!!
SPRHK is an unknown quantity at this point
Sounds like the converter box. MAKE SURE YOU GET ONE FROM THE RIGHT YEAR. THEY VARY AND ARE NOT INTERCHANGEABLE.
https://www.superhawkforum.com/forum...ne-quit-25073/
Old Apr 29, 2011 | 09:54 AM
Little_Horse's Avatar
2nd mouse gets the cheese
this is classic voltage regulator failure start there, its extremely rare cdi boxes or converters go out without something else frying them, so start with the r/r and the battery checks but the bike will continue running even with a bad battery but will not with a blown voltage regulator.
Old Apr 29, 2011 | 10:13 AM
and this is the time of year when the R\R failure is most common due to riding the bike again after its winter nap.
Old Apr 29, 2011 | 11:41 AM
Remember the main 30A fuse is on the side of the bike and not with the rest of the fuses.
Old Apr 29, 2011 | 12:03 PM
dutchdude's Avatar
moto gp wannabe
Thanks all - now off to check and then find a regulator.
Old Apr 29, 2011 | 01:37 PM
Stevebis1's Avatar
And when you check the battery voltage be sure and put a load on it. When mine died it drove me crazy trying to diagnose because the battery showed 12 volts. Simple thing is to turn the key on and then put the meter to it...
Old Apr 29, 2011 | 08:40 PM
dutchdude's Avatar
moto gp wannabe
Ok - it's the 30 amp main fuse - (thanks lazn) that keeps blowin, even with the key off it blows the second the cap goes on the starter relay - relay checked out ok - so i pulled the lead off the starter and replaced the fuse again, this time it did not pop the fuse-reconnected starter- turned key on and off several times- bumped the starter -no problem - so I started it up and after 3- 5 seconds- pop goes the fuse. i am gonna check the r/r in the morning, and keep checking from there. dangit ,there goes the first nice saturday this year.
Old May 2, 2011 | 09:15 AM
dutchdude's Avatar
moto gp wannabe
it does seem to be the season for the rr failure syndrome- I see there are too many threads to count regarding this issue- I ordered the Ricks replacement unit, it has the cooling fins and a bigger heat sink on it and it is supposed to plug right in with no rewiring needed. Anyone use this Ricks unit?
Old May 2, 2011 | 10:18 AM
Yep quite a few have them and in my opinion it goes like this from worst to best:
1) Original pre 2001 R/R
1.5) Non branded Chinese Finned R/R replacement (mine lasted 3 years)
5) Original Post 2001 R/R
5.5) Rick/Electrosport R/R
6) Yamaha/Suzuki non Mosfet R/R
10) Yamaha/Kawi/Gsxr Mosfet R/R (just swapped to this)
Numbers skipped to show quality difference. (Tweety could better number quantify the quality difference, but this is my guess)
Old May 2, 2011 | 11:10 AM
geekonamotorcycle's Avatar
Yah its that time of the year happened to me last night
YouTube - 05-01-11 Another Day another blown rectifier
05-01-11 Another day another blown rectifier « Just a Geek On a Bike
Same thing except my Main fuse blew.
Little_Horse
Feb 15, 2011 03:49 PM
8541Hawk
Aug 29, 2010 10:30 AM
HRCA#1
Dec 30, 2008 08:19 AM
sam0182
Oct 18, 2007 11:20 AM
RVO27
May 13, 2005 11:00 AM
