Russell SS Brake Line Install Troub
1 Attachment(s)
Here is what I ordered from DennisKirk.com http://www.denniskirk.com/jsp/produc...Id=&mmyId=2028
On the box it says 98 vtr1000f Frt brk Ln Part No: 09362 Heres the Bike. There is a hardline junction where the lines split off to the calipers. How does the Russell kit replace that? Im a little stumped here. Thanks Attachment 27256 |
you lose all of that junction box (not a bad thing) and you use the double banjo bolt at the MC and run two separate lines - one to each caliper. The longer goes to the left caliper. The only issue is bleeding. once you get it all hooked up you will have to bleed it at the banjo bolt early to remove the air. very simple to do but will be necessary.
THANKS. Figured it out finally lol. The banjo bolt is where it attaches to the reservoir? Is this like a car where I top off the reservoir then undo the bleed screws on the calipers?
Originally Posted by Ludicrous_Speed
(Post 271610)
Cool thanks for help, the job is complete.
