Running on 1 cylinder
Old Mar 30, 2005 | 09:31 AM
faz's Avatar
faz
faz
how do you know it was running on one cylinder?? how did opening the lid help get it from one cylinder to two??
Old Mar 31, 2005 | 02:02 PM
faz's Avatar
faz
faz
Have you eliminated possible electrical issues?? do you know that the missing cylinder is getting spark?
Old Mar 31, 2005 | 05:58 PM
superbling's Avatar
Re: Running on 1 cylinder
When I was experimenting with needle height with my factory jet kit needles, I had one pop (fly) off during one of the installations so I can see that happening.
I'm not advising to do this but I'd personally probably try to make one with a dremel and a very, very small washer until I could get a real one somewhere.
Old Apr 1, 2005 | 09:28 AM
divingindaytona's Avatar
Remember stock is BAD!
Check your petcock hoses. Sounds like one of the tubes is kinked/plugged.
I have seen this happen to other motorcycles and its normaly related to the petcock.
In the superhawk the petcock is fead by vacuum lines. A plugged vent line will produce this same symptom.
Also you may want to check your plug and see that 1 the coil is working and 2 the plug is firing.
Newbusa
Oct 25, 2009 09:00 PM
skoshere
May 6, 2009 10:05 AM
jmarch305
Jan 28, 2009 11:44 PM
sparkyharley
Jul 5, 2008 10:48 AM
calitoz
May 6, 2007 08:28 PM
