RT Piston
Old Nov 25, 2012 | 12:50 PM
lgaszynski's Avatar
lgaszynski is on a distinguished road
RT Piston
Hi
I have some question.
I end working with front cylinder and start rebuild a rear head.
I take out the rear head and start to clean the clean a top surface of piston.
When i start cleaning i feel that the piston is going a little left and right and give a little noise puk puk puk. When i try to do it up and down noting happens, up and down piston don't move. I did not feel that in front cylinder.
The compression was about 10,8 11 bar in front and rear cylinder.
I check this only wen piston was in top position and i did not check the surface of cylinder when piston going down. I remember that when i start the motor last time and give a little rpm then start a noise from rear cylinder and everything was good when the motor have work temperature.
Did you know what is to do, what i need to check or what in need to replacement
Łukasz
Old Nov 25, 2012 | 04:27 PM
JN607's Avatar
SHawk Member
JN607 is on a distinguished road
Originally Posted by lgaszynski
Hi
Łukasz
I no understand you english.
Old Nov 25, 2012 | 06:12 PM
It is rather hard to tell without a complete tear down but it sounds like a wrist pin issue.
The only way to fix it would be a engine rebuild.
uchi
Sep 20, 2010 08:54 PM
Streaky
May 2, 2007 08:06 AM
lotp
Feb 22, 2007 05:41 PM
AZZKIKER
Dec 16, 2006 10:41 AM
killer5280
Oct 3, 2006 09:03 AM
