Revving while idling
Old Apr 5, 2019 | 10:39 AM
zole2112's Avatar
zole2112 is on a distinguished road
My son and I bought an abandoned 1999 Superhawk late last summer and I just got it running and idling this spring. I haven't worked on cycle engines before so this site helped me immensely. We removed and cleaned the carbs, I balanced the carbs and set the fuel screw out 2.5 turns. The bike runs good, fast as hell, but it will rev up and down when idling. We are thinking vacuum leak but should I go back and re-balance the carbs? Any other ideas would be welcome. The bike has exhaust slipons, I forget the brand.
Thanks!
Old Apr 5, 2019 | 12:02 PM
Check the plastic choke fittings .
Also make sure the carbs are seated correctly in the intake rubbers.
Spray some soapy water around any Vacuuam fitting to make sure there are no leaks.
Also check for leaks in the exhaust .
Make sure that your TPS is hooked up.
Old Apr 5, 2019 | 12:34 PM
zole2112's Avatar
Thank you, will work on that this weekend
yak600
Apr 3, 2017 10:22 AM
BKFerrand
Oct 23, 2016 06:36 PM
avramd
Apr 26, 2010 06:33 PM
JoeSnowden
Mar 20, 2009 09:07 AM
Little_Horse
Dec 14, 2008 12:50 PM
