Reg/Rect problem...
Guest
Posts: n/a
Reg/Rect problem...
Hey, nice to see another SH forum pop up. Well, here is my problem, my bike died on me this morning like I just turned off the key,not a spit or sputter. I checked the fuses and found that the 30a main was blown. I tried putting in a new one with the key off and it kept popping it. I looked in the manual and disconnected everything coming off of the starter relay and found out that the problem is in the r/r. I checked the r/r with my multimeter and came up with continuity on the prong just above the green prong. There was no continuity on the other two. Does this look like an r/r that is shorted out? Maybe someone can check an r/r that they know is good to see if you come up with something different.
Thanks,
Mike in LB
Thanks,
Mike in LB
