Reg/Rect problem...
Hey, nice to see another SH forum pop up. Well, here is my problem, my bike died on me this morning like I just turned off the key,not a spit or sputter. I checked the fuses and found that the 30a main was blown. I tried putting in a new one with the key off and it kept popping it. I looked in the manual and disconnected everything coming off of the starter relay and found out that the problem is in the r/r. I checked the r/r with my multimeter and came up with continuity on the prong just above the green prong. There was no continuity on the other two. Does this look like an r/r that is shorted out? Maybe someone can check an r/r that they know is good to see if you come up with something different.
Thanks, Mike in LB |
Re: Reg/Rect problem...
I'll check mine for ya tonight.
I'm just up the road in Torrance (work) if you wanna try to swap them one evening. Drop me an email if so. |
