Re Jetting
Wish I woulda known that 10 hours ago....which brings me to my next question.
So I drilled out part of the screw. I have reason to believe the screw didn't turn that much while I was drilling and I just took the top 1/4" off. It's not open or anything. Does the screw still function? As in does that 1/4" I took off need to be there? And if I could find a way to turn the screw should everything function okay?
Dremel a slot in it and remove it. Then go to the Honda dealer and order a new one.
A good start on pilot screw adjustment is 2.5 turns out from "lightly" bottomed out.
Oh, and when you initiate a thread with a technical question, it's a good idea to check it frequently since there are a lot of guys with very good info.
Because I'm stupid, I'm going to ask: Is #6 the pilot screw that I want to replace?
http://www.servicehonda.com/look-up-parts/03
Thanks all!
Thanks all!
Thanks all!
Thanks all!
http://www.hondapartsline.com/fiche_...1998&fveh=4077
I hate being stupid sometimes :P
