RC51 Cluster Swap Question
Old May 20, 2007 | 07:41 PM
SNGPerformance's Avatar
SNGPerformance is an unknown quantity at this point
Okay, I've got everything together now. Only two things I haven't had the time to figure out. Tach doesn't work and the Temp gauge doesn't work. Does any one know what is needed or at least some ideas? Thanks!!
Old May 20, 2007 | 07:58 PM
superbling's Avatar
I think you are dealing with the issues of a FI vs Carb'ed bike (i.e., no computer). The 51 temp sensor most likely is a typical honda 3 wire assembly. Not sure about the tach problem.
Old May 20, 2007 | 10:31 PM
kai ju's Avatar
Hey SNG, I'm running CBR929 gauges on my bike and the tach doesn't care where it gets it's signal from as long as it's the YL/G wire from the ECM.
That's the same color for both the RC51 and the VTR. ( Just looked it up on their respective wiring diagrams )
So is the ground ( G/BL ) and the switched power ( BL/BR ).
In regards to the temp gauge, Honda is pretty consistent with their wire colors in regards to function, just make sure that you have a good, clean ground and that the colors are matched.
Kai Ju
Old May 21, 2007 | 07:26 PM
Thanks guys. I'll check it out.
Old Feb 10, 2010 | 12:11 PM
bealsey's Avatar
bealsey is on a distinguished road
I am doing the same swap interested if you had any luck getting the gauges to work properly?!
Old Feb 10, 2010 | 05:51 PM
Holy thread resurrection, Batman!
Old Feb 10, 2010 | 07:28 PM
AngryOlaf's Avatar
Threads never die... they just quiet down for a while.
Old Feb 10, 2010 | 09:31 PM
scatterbrained's Avatar
Squid Poacher
scatterbrained is on a distinguished road
He's got a good point, there needs to be closure for us to move on.
Old Jun 9, 2010 | 12:13 AM
BBB's Avatar
BBB
Good Root
BBB is on a distinguished road
Have we now moved on?
Old Jun 9, 2010 | 12:35 AM
Ok, since people want closure (and are to lazy to read the other threads, which answers this) I'll put it here...
The tach works unless you mess up the wiring, there is absolutely no difference with a digital LCD or a manual needle... The gauges from 97 onwards on the VTR is "digital" in the circuits behind the gauge face... If it doesn't work, you messed it up...
The temp gauge is another matter, the ECT on the VTR is separate from the sensor for the gauge and not a common three pronged one as on the newer models (CBR & RC) so you need to find a replacement sensor with the right resistance range... You can wire it up to "work" but the display will be off by a fairly big margin on the stock VTR sensor...
Now go read the other threads...
Old Mar 1, 2011 | 05:21 PM
1971allchaos's Avatar
And the LAST words, Fall Heavy, for closure....
Old Mar 2, 2011 | 01:56 AM
Actually, since then I have solved that problem... If anybody want's too I'll gladly provide them with the manufacturer and the rest of the info to get the correct sensor... You need to cut the connector of it and wire it together, but other than that it's plug and play...
Old Mar 2, 2011 | 10:22 AM
OK I'll ask....what is the manufacturer and the rest of the info to get the correct sensor...
Old Mar 2, 2011 | 11:17 AM
calitoz's Avatar
Escape Reality
We really need a KB write up on this. Yeah there are several great posts on the subject but I nominate Tweety to author a KB sticky...
mikstr
May 24, 2012 05:52 PM
meanhawk98
Feb 12, 2012 08:48 PM
mikstr
Jan 15, 2011 10:33 AM
uchi
Apr 20, 2010 04:39 AM
thefauxnarchist
Nov 28, 2008 10:18 AM
