RC 51 Wont run !!!!!
Old Jun 23, 2008 | 02:59 PM
billbo199's Avatar
billbo199 is on a distinguished road
Hey was just wondering if anyone could help ? Having problems with a friends 2001 RC51 at low end revs between 2 and 3000 rpm the bike is dying for a second its like shutting off the ignition for a second then will pull through the rest of the rev range fine !!!! have tried a few things like wiring connections all ok had the tank off checked everything in the airbox is fine cdi is ok no damage to unit or wiring running out of things to try any help would be apprecated
Old Jun 23, 2008 | 05:38 PM
SlowHAWK's Avatar
You might wanna try over at Speedzilla.... theres a pretty active RC51 forum over there where you might find some people a bit more familiar with the RC's.
J.
Old Jun 23, 2008 | 06:13 PM
water in the fuel
Old Jun 24, 2008 | 10:05 AM
billbo199's Avatar
[quote=SlowHAWK;169270]You might wanna try over at Speedzilla.... theres a pretty active RC51 forum over there where you might find some people a bit more familiar with the RC51
Hey SlowHawk thanks ill check that site and see if someone can help
Also were you doing a SSS conversion ???? i have seen some of the posts regarding Caltoz conversion i am in the process of doing one right now and have found your measurements to be more true !!!
Mr.Lojo
Feb 7, 2015 02:48 PM
Pimpsterbim1
May 14, 2009 04:32 PM
vermontzx6r
May 9, 2009 12:50 PM
ali_squidz
Apr 7, 2007 05:57 PM
99Hawkboy
Aug 29, 2006 11:00 PM
