R1 reg/rec useable??
Old May 6, 2010 | 01:44 PM
I know about the R^ but can I use an R1 R/R the same way????
Old May 6, 2010 | 04:43 PM
Yep...
Old May 6, 2010 | 05:10 PM
doomcookie's Avatar
doomcookie is on a distinguished road
I got an R1 R/R
Old May 8, 2010 | 10:24 AM
So its the same pin scheme as the R6 sticky thread swap?
Old May 8, 2010 | 10:47 AM
doomcookie's Avatar
I got a thread here somewhere in general i can get it.. Which one are you getting i got the 04 model which is big and work good.. doesn't heat up as bad. My model have 2 plug but same number of wires. Can't find it but if you get the one i got then it should go YYY RG
Old May 8, 2010 | 11:20 AM
There seems to be two variations... One with a single plug and one using two like doomcookies... Both are documented in threads here, so you are looking at one of them...
Worst case scenario if you get it wrong is a blown fuse...
sheldonsl
Nov 16, 2010 03:09 PM
motormouth
May 31, 2010 02:32 AM
Shaggie
Mar 20, 2010 08:32 PM
NCDave
Nov 15, 2009 11:09 AM
CentralCoaster
Jul 21, 2008 10:54 PM
