R1 reg/rec useable??
I know about the R^ but can I use an R1 R/R the same way????
Yep...
I got an R1 R/R
So its the same pin scheme as the R6 sticky thread swap?
(Post 265170)
I got a thread here somewhere in general i can get it.. Which one are you getting i got the 04 model which is big and work good.. doesn't heat up as bad. My model have 2 plug but same number of wires. Can't find it but if you get the one i got then it should go YYY RG |
There seems to be two variations... One with a single plug and one using two like doomcookies... Both are documented in threads here, so you are looking at one of them...
Worst case scenario if you get it wrong is a blown fuse... |
